Step 2How I made it
I started by cutting the foam board down to 10" blocks, then taped them together into a 5-sided cube.
To give it the look of individual cubes, I made a V-shaped groove along each face by cutting into the foam board with a box cutter.
Then I taped over each of the grooves, pushing the tape into the groove as much as possible. To make it better, I then cut the tape along each groove to split it, then I pushed it in again so that the two edges separated.
The stickers:
I measured my real cube and it was 55mm wide and each sticker was 15mm wide. So I scaled the width of my box by 15/55, coming up with 7.2mm width for each sticker. I think this made all the difference in getting the proportions right. Then I stuck the stickers on with double sided tape.
There are multiple color layouts in existence, but I tried to make mine the same as the color layout of the original version (lest I get called out for ignorance at a halloween party, yeesh!) :)
I thought of this costume because Erno Rubik is a Hungarian just like me and we even have the same birthday. Long live the Cube dorks!
I stole my friends plastic hat and wore the cube on top of it
