Introduction: Rubiks Cube Tricks: Slashes
quick and easy Rubiks Cube trick to show your friends
Step 1: Intro
The Slash trick is a four move process. You can do it really quickly and that is what makes it impressive. I will teach it two turns at a time
Step 2: Step One
The first two turns are R and L. R and L are opposite sides from each other and they move in different directions. R goes up and L goes down
Step 3:
if you start with the blue side facing you this is what it should look like
Step 4: Step Two
The second two turns for slashes are F and B. F is the front and B is the back. the front moves clockwise and the back moves counterclockwise.
Step 5: Repetition
That's it! those are the only four turns you need to know. Repeat the sequence twice more to achieve the pattern.
Step 6: Bonus
if you repeat the sequence another two times you can form the plus pattern
Makerspace Contest
