Introduction: Rubiks Cube Tricks: Snake
Picture of Rubiks Cube Tricks: Snake
awesome Rubiks Cube trick and it's easy to learn
Step 1: Lets Begin!
Picture of Lets Begin!
it doesn't matter which side you start on but I usually start facing the white side
Step 2: Fundamentals
Picture of Fundamentals
The main thing you need to know is the name of the side rotations. each rotation is represented by a letter. ther are 9 turns that are represented. U,D,E,S,M,F,B,R,L. each one means something different. The is one other important letter, letter i. the letter i tells you which direction you need to turn in
Step 3: Direction Map
Picture of Direction Map
This is a direction map. It specifies what each letter means. note: no matter what side you are facing or what colors are on it, the letters never change. They always represent the exact same thing. For some reason they made me take out the picture of the direction map so here is a link http://mrsyoast.weebly.com/uploads/9/1/3/6/9136913...
and https://rubiks.com/uploads/blog_entries/ESM.jpg
Step 4: Turns 1-3
Picture of Turns 1-3
remember you can start in any direction you want. The first moves are L U Bi . That means left, up, back . consult the map to see which direction you need to turn in
Step 5: Turns 4-6
Picture of Turns 4-6
The next three turns are Ui R Li
meaning up, right, and left. again check the map to make sure your turning the correct way. If you started facing the white side this is what yours should look like. Otherwise the results may Cary, but you will end with the same resulys
Step 6: Turns 7-9
Picture of Turns 7-9
B,Ri,F
Step 7: Step 10-14
Picture of Step 10-14
Bi, D ,Ri ,D ,Fi
Step 8: Finish
Picture of Finish
The pattern should look like this when you finish. each side should have three odd ball colors , those colors should line up with the odd ball colors on either side. The faster you do it the cooler it looks, so keep practicing.Enjoy!
About This Instructable
590views
1favorite
License:
More by sebnibo:Worlds Greatest French FriesDIY Casey Neistat GlassesEasy Home Made Bread Crumbs
Add instructable to:
