Rubik's cube chest of drawers
 by makendo
Contest WinnerFeatured
30 years on from its invention, Rubik's cube is still instantly recognizable. People like picking it up, turning it a few times, maybe doing a side or two (or five, as a braggart in my class once memorably claimed). Solving the cube remains a reasonably rare feat - you're either smart enough to have figured it out yourself, or geeky enough to have followed a how-to, and most people are neither (then, of course, there is the astonishing Feliks Zemdegs...).
Rubik's cube is not just the quintessential hand-held puzzle, though: it's also an iconic piece of design, so I co-opted it when making a new chest of drawers for my son's room. This cubic piece of furniture has only one of the three required axes of rotation, so is unsolvable in the conventional sense, but can be arranged in any configuration you like by non-sporting means. The drawers do pose a brain-bending challenge: the first thing you have to solve is detecting that they're there, and all three have hidden locks in different locations.
Step 1: Design
Unsurprisingly, there are lots of bits of furniture around that are based on the Rubik's cube; coffee tables are particularly popular, and for 980€ (!!), you can even buy a Rubik's cube locker. I wanted to do something different, and use lazy Susan bearings to achieve at least one axis of rotation - they're cheap, really strong, and add a wacky dimension to a chest of drawers.
The design is simply three boxes, each containing a single drawer. Their construction is basic - they're made of 1/4" and 1/2" plywood (which you should get precut at the lumber yard into two 2'x8' sheets), and assembled using a brad nailer and wood glue. This method of construction is super fast and precise, and results in really strong objects. The main challenge in this build is cutting the pieces with high precision - if you can't cut plywood to within 1 mm, you should probably practice on something simpler until you can. Having said that, I'm no pro and I've never made a chest of drawers before, so this project is NOT fancy woodworking by any means! If you weren't fussed about the drawers, it would be dead easy - it's just three boxes and a couple of lazy Susans, and you'd have a cool coffee table with no additionally functionality aside from rotatability. Deluxe Scrabble, anyone?
I was going to simply glue the "stickers" on to decorate the outside - or even just paint them on - but the future owner insisted he had to be able to scramble and "solve" the cube, so I enabled this with the help of rare-earth magnets for holding power and short dowels for positioning. I'm glad I did - it's more fun now, and the colors can be selected to match your mood or decor, including impossible combos of color (insofar as the real cube goes).
The puzzle is a little under 60 mm across, and this chest of drawers is exactly 600 mm across, so it is in approximately 10:1 scale. 1000 regular Rubik's cubes would therefore fit inside.
There are cubes that are 2x2, 4x4, 5x5 etc, so if you need more (or less) drawers, there is an obvious design solution...
Step 2: Materials and tools
Materials:
One and a half sheets of 1/2" plywood
One and a half sheets of 1/4" plywood
Two 12" lazy Susan bearings
Three pairs of 22" full extension slides
Shorter screws than those provided with the above, say 60 1/2" flat head screws
45 3/8" rare-earth magnets (in hindsight, the 9 on the top are not really necessary, so 36 would be enough)
54 3/8" steel washers
54 6 mm x 30 mm dowels, cut in half
Wood glue
Epoxy glue
Brad nails
Undercoat
Gloss paint in six different colors of your choice. I used spraypaint, as it's a relatively cheap way of getting small quantities of paint, they keep well, and they're handy to have around.
Black gloss paint
Close to $200 all up.
Tools:
Circular saw, table saw, miter saw, router, orbital sander, cordless drill with a 3/8" forstner bit, and a brad nailer.
Step 3: Cut your plywood
Cut the plywood into the following dimensions. You'll notice that my extra half sheet of 1/2" ply actually came from offcuts I had lying around from other projects (yes, even after making the Lego construction table, I still had a few old cupboard doors left over...).
1/2" plywood (11 mm thick)
6 of 600 x 582 mm (tops and bottoms of cases)
6 of 582 x 178 mm (sides of cases)
3 of 600 x 200 mm (drawer fronts)
6 of 543 x 160 mm (sides of drawers)
1/4" plywood (7 mm thick)
3 of 600 x 200 mm (backs of cases)
3 of 550 x 550 mm (bottoms of drawers)
3 of 550 x 160 mm (backs of drawers)
54 of 165 x 165 mm (the "stickers", see later for more detailed instruction on these)
I always cut using a straightedge with the circular saw, which gives you a perfect straight line but requires a few clamps. Get a decent finishing blade, you'll save yourself a lot of sanding. I use Freud thin-kerf blades in all my saws - the quality is excellent, and it reduces the load on the saw and the amount of sawdust produced. I used the bench saw and miter saw wherever possible, because the set-up is quicker. Cut to a stop using the miter saw to ensure reproducibility.
Step 5: Assemble cases
Assemble the cases with wood glue and brad nails, as shown. Leave to dry overnight, then sand, fill any imperfections with wood filler, and sand again.
Step 7: Add drawer faces
Attach the drawers to the slides, and check the fit (whether they slide in and out nicely). Put the case on end, and drop something in behind the drawer so it will sit slightly proud when closed. Line up your drawer front, and mark and cut to fit. Glue and nail to the drawer, again taking care with the nailing (I recommend transferring the lines to the front to avoid errors). Round the edges of the drawer front to match the case, remove the stop, and sand, fill and sand again.
Step 8: Groove the faces
To create the illusion that the cube can spin conventionally (i.e. on three axes, not just one), I faked it using a router with a V-shaped bit to cut grooves in all the exposed faces. Use a guide - because it's hard to clamp on to a face, I just tacked the guide in place temporarily using the brad nailer the correct distance from the desired groove. I ripped a piece of wood exactly the right width so I could rout both sides using the same guide (with my router, it needed to be 56 mm). The groove doesn't look exactly like the horizontal gaps, of course, but the visual illusion holds at least at first glance.
Step 9: Cut squares
I measured each cubie to be 19.1 mm on a side, and each sticker as 15.6 mm, about 81% of the size. So I rounded up to the nearest 5 mm (165 mm for a "sticker" for a 200 mm cubie) and ripped much of one sheet of 1/4" plywood into 170 mm strips. I then set a stop on my miter saw to 165 mm and made two cuts for every square, to ensure the 54 squares were as close to perfect as possible. I ganged them all together with a strap, and routed and sanded the corners of all squares simultaneously. This step was pretty quick, and all the components were done now. Just painting and hardware to go!
Step 11: Washers and dowels
Make a template for this step. Drill two dowel-sized holes part way into each "sticker" (about 3/4 the way through), and with the Forstner bit, drill a shallow (just deep enough for your washer) hole in the center. Repeat 54 times! You really need two drills, or the swapping of bits will drive you nuts. Now cut 54 dowels in half by taping them to a scrap piece of plywood and running them through the bench saw. Glue the half-dowels into the holes. Epoxy the washers into the shallow holes in the center.
Step 12: Paint stickers
Undercoat, then spray paint the edges and top of each sticker in whatever combination of colors you like - we stuck with the conventional white/yellow/orange/red/green/blue. I let the future owner pick exactly which shade of each he liked of each. I spent a few minutes painting one coat, then returned about 15 minutes later and did another. I used about half a can per set of nine, I reckon.
Step 13: Holes and magnets
You'll need to use a template again. Use the previous template to make this one; it needs to be 200 x 200 mm. Make the dowel holes slightly bigger (I used 15/64" for the dowel holes, and went to 17/64" for these). Drill just deep enough for the magnet to sit flush with the surface (conveniently, this was just into the second layer of ply, so I just eyeballed it), but bore all the way through for the others. Repeat 45 times (you don't need to do the base, for obvious reasons!). Glue the magnets in the holes using a thin layer of epoxy.
Step 14: Lazy Susans
The 12" lazy Susan bearings are pretty low profile (9 mm), but I reduced the gap between cases further by routing out a layer of plywood from the cases (3 mm from each) to set them into. I just freehanded it after marking the lines carefully. I greased the ball bearings - this makes it stiffer but quieter, both desirable for this application. The lazy Susan bearing has to be PERFECTLY centered. I screwed one side on and just epoxied the other.
Step 15: Add locks
I added a simple hidden lock to each drawer, all in different places. I just drilled holes through case and drawer from the side, and stuck a dowel in. To unlock, you just remove the correct sticker and push in the dowel. It's low tech but effective, and I don't anticipate it spending much time locked, but it's nice to know you can.
Step 16: Solve the cube!
Add the "stickers" however you like to get the design you want (store the leftover nine stickers in one of the drawers, of course!). Change the stickers and make a new piece of furniture. Take it for a spin. Play some Scrabble (or 3D Settlers of Catan). Leave it in the middle of your living room as a coffee table. Bring it with you to a park and confuse strangers. Organize your underwear in high geek style. Talk to it. Sit on it and slowly orbit. Put your favorite boardgames in it. Challenge people to solve it one handed, and/or blindfolded, and time them. Use it as a stand for your prize-winning laser-cut, LED-lit, Arduino-controlled, solar-powered, steampunk-themed, EL wire-crocheted Halloween cupcakes...
Want to buy one? I'm going to make five sometime this summer (2012). They will be to an improved design (bigger lazy Susans, different joinery, high quality Baltic birch plywood, simpler magnet system). They'll cost about $6-800 + shipping (about $150-200 to the US, slightly less in Canada). If you're interested, send me a PM and you'll get first right of refusal.
Many thanks to the following sites for featuring this build: make, boingboing, hackaday, neatorama, ohdeedoh, geekosystem, technabob, manmade, babble, wins.failblog, design-milk, storagegeek, discovery, thisiswhyimbroke and others; thinkgeek for tweeting about it, and of course instructables users for all the great feedback. Cheers!
Some people have even made replicas! See
here, here and here. If you make one, please send me a link or post a picture in the comments.
1-40 of 97Next »
nmertens says: Jan 4, 2013. 12:03 PM
I come from Belgium and i dont speak english but i have make my own rubik's cube !
It does not turn. This is the first piece of furniture I make and I'm very happy !
Thanks for your instructable !
2012-12-27 22.42.03.jpg20121227_224904.jpg20121227_224914.jpg20121227_225324.jpg
makendo (author) in reply to nmertensJan 4, 2013. 12:05 PM
Fantastic! Great job, it looks really nicely finished. Thanks for posting the pictures.
rcfreak2 says: Dec 18, 2012. 9:25 AM
hey how much did this cost?
makendo (author) in reply to rcfreak2Dec 18, 2012. 10:14 AM
see step 2
bowlen199 says: Sep 17, 2012. 2:35 PM
amazing build by the way as everyone else above agrees. I love the interactivity of it and how well it was finished.
very roughly how long do you think this took you to build?
makendo (author) in reply to bowlen199Sep 17, 2012. 5:08 PM
Thanks. About 6 weeks, very much part-time. Maybe 20 hours, as a wild guess?
HollyMann says: Apr 12, 2012. 9:22 AM
you are amazing! I LOVE IT!!!!!!!
bfk says: Nov 23, 2011. 1:33 PM
So cool! I want one & I'm over 60
mad_mat says: Nov 12, 2011. 3:50 AM
Epic build Makendo, top shelf.
'bout how many hours?
makendo (author) in reply to mad_matNov 12, 2011. 12:03 PM
thanks. Hmm, really hard to guess how many hours, because I built in in scraps of time on weekends and evenings over about a six-week period. I know I built the drawers themselves very quickly - maybe a few hours - but slowed right down when it came to the repetitive parts, because I'm easily bored and cutting/drilling/gluing/painting all those stickers wasn't particularly exciting work. It would be a hard project to do quickly I think, because I seem to remember doing a lot of small jobs that then took time to dry, whether it was glue or paint.
antony.trupe says: Nov 9, 2011. 11:10 PM
Almost have mine finished.
https://plus.google.com/u/0/109527486558392328338/posts/hfEAKVn6Ff8
makendo (author) in reply to antony.trupeNov 9, 2011. 3:46 PM
Antony - that's fantastic, good work! Keep me updated, it would be great to see the fully stickered version.
Melissa W says: Nov 9, 2011. 5:22 AM
This is gorgeous. Seriously love it. I featured it at The Storage Geek With full credit and link back.
makendo (author) in reply to Melissa WNov 9, 2011. 1:03 PM
Thanks Melissa.
majorson says: Nov 8, 2011. 2:10 PM
Inspiring! lovely father..
If you intereted, Learn:
How to solve a Rubik's Cube
(Great animated guide for beginners, I'm sure you'll success shortly..)
Majorson.
baba87 says: Nov 5, 2011. 4:25 AM
Awesome. You should sell these!
scaremeifucan1428 says: Nov 3, 2011. 4:47 PM
Ok I want to make a chest, but not one this huge. I was thinking something more like the size of a jewelry box. What would my new dimensions be and would any of the steps be different? I would love this as a chest, but I just don't have the space in my room. It would be great if you could help me make a smaller version of this!
makendo (author) in reply to scaremeifucan1428Nov 3, 2011. 7:58 PM
Well, you can get smaller lazy Susan bearings (see materials step) and you wouldn't need the metal slides for a dinky little cube like the one you're planning. You would need to be good at making small boxes, though, which is an art I have no experience with (my background, such as it is, is in carpentry rather than woodworking). The removable stickers would be pretty fiddly to scale down, so you might have to come up with another solution (just painting them on would be easiest, or sticking on vinyl of the right colors).
As for your dimensions - how big is a jewelry box? That's how big it needs to be. About 1/3 the size of this one, i.e. about 1'x1'x1' sounds about right. It would be a cool project - good luck with it!
lanvy-nyc says: Oct 30, 2011. 9:40 PM
WOW! U REALLY OUT DID YOURSELF!!
karbuckle says: Oct 27, 2011. 6:21 AM
This is genius at it's best. I didn't realize it was seperate drawers on each layer. I thought it was just a square box with the lid that opened for storage. I will build these for my kids for sure!
makendo (author) in reply to karbuckleOct 27, 2011. 8:53 PM
Thanks, good to hear - post a photo if you get it done!
DisplacedMic says: Oct 19, 2011. 6:12 PM
Sorry to keep bugging you with questions - but i am in the market for a new router - any recommendations? would i need a variable speed router for this project?
Im looking at the Porter-Cable 690LR 11 Amp Fixed-Base Router which is ~ 120 shipped.
thoughts?
DisplacedMic in reply to DisplacedMicOct 19, 2011. 6:15 PM
oops - and also the DEWALT DWP611PK 1.25 HP Max Torque Variable Speed Compact Router Combo Kit which is a variable that comes w/ a plunge addon...
makendo (author) in reply to DisplacedMicOct 19, 2011. 6:31 PM
I've not owned a Porter-Cable tool so can't comment on them, but I've used a few De Walts and the quality is excellent - my DW miter saw is fantastic. I have a single speed 1.25 HP Makita plunge router, and it's good. You only need variable speed if you're planning to use big bits (not necessary in this project), in which case you should get one with a bigger motor. I hardly ever use the plunge capability, but it's handy to have, so the combo kit sounds pretty smart. Good luck with the build - post photos if you get it done!
ggardner7 in reply to makendoOct 23, 2011. 7:29 AM
this is super cool
Bard says: Oct 13, 2011. 12:54 PM
Just out of curiosity how much did you sell it for?
makendo (author) in reply to BardOct 13, 2011. 1:44 PM
My kids would riot it I sold it! I've made one, and it is not for sale.
Bard in reply to makendoOct 14, 2011. 11:27 AM
the way the instructible was written it sound like it was a commissioned build that's why i asked. Nice design by the way.
makendo (author) in reply to BardOct 14, 2011. 11:37 AM
Ah, gotcha. Yes, it was - but the commission was issued by my 6-year old son. So the pay was lousy (i.e. 0) but the level of appreciation was priceless :)
DisplacedMic in reply to makendoOct 19, 2011. 5:01 PM
you are clearly a great dad!
stevemoseley says: Oct 18, 2011. 3:48 PM
Great stuff and beautifully built. It makes you wonder what other small items around the house need to be up-sized like this.
makendo (author) in reply to stevemoseleyOct 18, 2011. 8:09 PM
Many thanks Steve - I've seen a giant toothbrush, a match, a NES controller, an Fn key etc, with differing degrees of functionality... so clearly others have been thinking the same thing.
mary candy says: Oct 18, 2011. 5:03 AM
GREAT JOB !!!
I really love it.
Voted of course.
makendo (author) in reply to mary candyOct 18, 2011. 7:16 PM
Thanks mary candy.
HandyMan1959 says: Oct 16, 2011. 2:06 PM
makendo (author) in reply to HandyMan1959Oct 16, 2011. 3:25 PM
Hey, thanks for the tip-off. I also liked geekosystem's "Rubik’s Cube Chest of Drawers Looks Awesome, Greatly Increases Sock Retrieval Time" :)
schlieffenska says: Oct 16, 2011. 2:54 PM
I'm having one of my "AGGGGH! I wish I didn't live in a n rv!!!" moments right now. Way cool. Super, super cool.
Win Guy says: Oct 15, 2011. 3:17 PM
And... YOU MADE THIS?!?!? *Slams "Subscribe" button as hard as possible*
Amazing!
Win Guy
makendo (author) in reply to Win GuyOct 15, 2011. 6:57 PM
Thanks, Win Guy.
sconner1 says: Oct 15, 2011. 6:13 PM
Make sure the nails are far enough from the edges so the router bit doesn't hit them
1-40 of 97Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
