Step 11Washers and dowels
iImage Information
Make a template for this step. Drill two dowel-sized holes part way into each "sticker" (about 3/4 the way through), and with the Forstner bit, drill a shallow (just deep enough for your washer) hole in the center. Repeat 54 times! You really need two drills, or the swapping of bits will drive you nuts. Now cut 54 dowels in half by taping them to a scrap piece of plywood and running them through the bench saw. Glue the half-dowels into the holes. Epoxy the washers into the shallow holes in the center.
