3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Rubik's cube chest of drawers
Step 3Cut your plywood
Cut your plywood
Cut the plywood into the following dimensions. You'll notice that my extra half sheet of 1/2" ply actually came from offcuts I had lying around from other projects (yes, even after making the Lego construction table, I still had a few old cupboard doors left over...).
1/2" plywood (11 mm thick)
6 of 600 x 582 mm (tops and bottoms of cases)
6 of 582 x 178 mm (sides of cases)
3 of 600 x 200 mm (drawer fronts)
6 of 543 x 160 mm (sides of drawers)
1/4" plywood (7 mm thick)
3 of 600 x 200 mm (backs of cases)
3 of 550 x 550 mm (bottoms of drawers)
3 of 550 x 160 mm (backs of drawers)
54 of 165 x 165 mm (the "stickers", see later for more detailed instruction on these)
I always cut using a straightedge with the circular saw, which gives you a perfect straight line but requires a few clamps. Get a decent finishing blade, you'll save yourself a lot of sanding. I use Freud thin-kerf blades in all my saws - the quality is excellent, and it reduces the load on the saw and the amount of sawdust produced. I used the bench saw and miter saw wherever possible, because the set-up is quicker. Cut to a stop using the miter saw to ensure reproducibility.
2 comments
Oct 11, 2011. 7:02 AMjeff-o says:
Oooh, I do love the Diablo blade I have in my miter saw. I second your recommendation!
Oct 15, 2011. 6:10 PMsconner1 says:
I agree Diablo blades are excellent.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
213
Author:makendo
I'm probably off making something. Most likely a sandwich.
