The doll must turn a little, stop turning, stick his tongue out and continue turning. So cut some rubber band to the length of half of wheel perimeter...
Put motor and battery holder beside plastic sheet and mark wheel position on the plastic sheet. Then make a hollow for the wheel on the plastic sheet ...
Make some holes with drill on the plastic sheet to fasten the motor on the sheet by wires coming through the holes. Place the motor on its position an...
Attach a thread to the middle of the plastic red thin sheet, bend it and attach it to a piece of wood with glue and a nail. Attach other pieces of woo...
Turn on the motor till the wheel needle comes to highest position. Connect one side of pen inner tube to the wheel needle. Cut extra tube and connect ...
Draw the shape of the head on a thick paper and cut it out and make the head of the doll. Don't forget to make his mouth hollow. Attach the head to a ...
Pass a string through the pen outer tube. Twist some wool string on the pen tube, then pull them out of the tube and tie the string that have been pas...
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
