3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ruger Mark III Pistol Take Down and Assembly
Taking down and assembling a Ruger Mark III .22 caliber pistol for cleaning is not difficult, if done in the proper steps.  If not done properly, it can be frustrating.  If I let a long time pass without doing it, I forget how to do it.
Items needed are: a Mark III pistol, a paper clip, as soft plastic hammer, and a needle nose plier or a small screwdriver.
If I am not mistaken, the procedure is the same for a Ruger Mark II pistol.
Step 1Safety first
Safety first
Remove the magazine.  The magazine release button is under my left thumb.  Hold it down and pull the magazine from the bottom of the pistol handle.
I am working on newsprint to protect the table surface and to protect the gun parts.
22 comments
Sep 22, 2010. 11:05 PMjustin_ says:
Thanks for the great instructible! Had I found this before I took apart mine for cleaning the first time I would have one less scar on my hand!
Aug 23, 2010. 4:23 PMglorybe says:
No Way! You can not dry fire a rim fire pistol. You risk the pin being rammed into the receiver assembly resulting in a totally ruined Ruger. Read your Ruger manual. I owned one of these pistols and they must never be dry fired!
Sep 22, 2010. 11:03 PMjustin_ says:
Just to back up everyone else that responded, I have a Stainless Steel MK III and in the manual it says specifically to dry fire it.
Ruger even says to do it in their video in the "extras" section on the website:
http://www.ruger.com/products/markIIITarget/extras.html
Sep 3, 2010. 6:07 AMNachoMahma says:
Ruger Mark III manual (PDF)
.  Page 20, step 5: "With the muzzle pointed in a safe direction, push the safety to the “off” (F) position and pull the trigger to decock the pistol. The pistol can be dry fired as long as the firing pin stop is in place (see NOTE in step 5 on page 25)."
Sep 27, 2010. 2:42 PMglorybe says:
I suspect that there may have been changes to the Ruger assembly over the years. The one that I owned had a manual that was adamant about not dry firing the weapon. Apparently other folks had MarkIII pistols that could be dry fired. I don't know why the firing pin was ever made in such a way that any event would allow it to ram into the surrounding parts of the weapon. I can also say that it was not my favorite weapon as about every 15 rounds or so I would have to clear a non fired cartridge from the weapon. My other complaint would be in the difficulty of disassembly of the pistol. I have a 9mm now that I can disassemble so easily that it is almost a joke. It is a DA 9mm and apparently is patterned after a Beretta design.
Oct 30, 2010. 5:24 PMbmwsid says:
I also have one of these. I will NOT dry fire it. Like all things mechanical, your pistol just didn't like the particular ammo you were feeding it. Mine don't like Federals, but will fire any other brand I give it. I had an awful time trying to take it apart, so I didn't. I have had it since 1977, and it still functions fine, long as I don't put Federals in it! Wht take it apart!!! Leave it alone, and it will serve you fine.
Sep 3, 2010. 4:03 PMNachoMahma says:
. You might want to add a sentence or two advising people to check that the pin is installed before dry-firing. Maybe not - it doesn't look like something that would just fall out.
. Dry-firing any gun makes me slightly nervous. Both for safety (all guns are loaded, even if I just checked them) and mechanical reasons (it's bound to stress the firing pin if only a little bit; that stop is a lot harder than brass).
Sep 5, 2010. 4:37 PMTheBigNil says:
I like to use a disassembled Bic pen or similar to slip onto the latch. It helps give some leverage too
Sep 3, 2010. 4:50 AMRe-design says:
Nice job. One of my favorite pistols.
Aug 23, 2010. 7:06 PMmrdepo96 says:
Thank you for this great ible! i have the same Ruger, i do believe it's newer though.
Aug 15, 2010. 6:40 PMkill-a-watt says:
Why isn't this a featured instructable yet? I'm adding it to my faves.
Aug 13, 2010. 1:55 AMskunkbait says:
Good job Phil! It took me a quite a bit of study, the first time I took one of those (mine was a MkII) apart. I've got an older MkI now, but this'll still come in handy next time I clean it. Thanks!
Aug 12, 2010. 2:10 PMkill-a-watt says:
Thanks for such a great instructable. I'm glad you emphasized safety first.
I think it's really important to stress to the n00bs that you need to check to make sure the firearm is unloaded, and that the muzzle is kept pointed in a safe direction.
You don't really get to all of them because this is just a cleaning tutorial, but I'd like to list them for the sake of completeness:
The Four Rules
1. All firearms are always loaded
2. Never let the muzzle of a firearm point at anything you are not willing to destroy
3. Keep your finger off the trigger until you are ready to shoot
4. Be sure of your target and what lies beyond it
It's been noted that you usually need to break two or more rules to really screw things up, so I try to instill  good habits that are so ingrained that I feel funny breaking even one of them.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
476
Author:Phil B
I miss the days when magazines like Popular Mechanics had all sorts of DIY projects for making and repairing just about everything. I am enjoying posting things I have learned and done since I got my...
more »
