Introduction: Ruler Crossbow
Picture of Ruler Crossbow
Learn how to make a crossbow out of easily available household/office items- not least of which, a ruler! Why only use a ruler to measure stuff? Turn it into a weapon instead!
Step 1: Materials
Picture of Materials
The things you'll need:
A Ruler (steel, wooden or plastic- I happened to have steel)
Two unsharpened pencils (or something of equal length like disposable chopsticks)
Rubber Bands (amount depends on how tense you want the bow)
Strong Tape (I used 3M brand clear duct tape- strong glue may work too)
A drinking straw
Medium sized Binder Clip (wide enough to fit over the end of the ruler)
3M Wall Hook things (as a handle/grip)
Bamboo (Shish Kebab) Skewers (for arrows)
Step 2: Construction of Bow
Picture of Construction of Bow
Step 1:  Tape the two pencils together. Make sure you leave either end of the pencils
               untaped so you can can get the rubber bands between the pencils later
Step 2: Tape the two pencils to the top of the ruler so they are perpendicular to each
              other- like a cross without the top.
Step 3: Rubber Bands
Picture of Rubber Bands
Step 3:  I used four rubber bands, but looking back I probably could've done it with two
               and gotten more power. Anyway knot the bands together as shown in the
               picture below.
Step 4: Attaching the Rubber Bands
Picture of Attaching the Rubber Bands
Step 4:  Slide one of the double over bands between the two pencils at one and tape in
               place. Do the same with the other end.
Step 5: Final Touches
Picture of Final Touches
Step 5: Cut a small length of the drinking straw. (not too long or the bands will catch on
              the straw and therefore decrease the amount of power. Tape the straw piece to
              the ruler near where the tip of you arrow will rest when loaded.
Step 6: Take the 3M Wall Hook thing and attach it to the underside of the ruler (hook
              end facing you) to use as a handle/grip.
Step 7: Put the binder clip on the end of the ruler. If your ruler is steel/metal. the clip
              may slide around easily. Just add a piece of tape the part of the ruler where the
              clip grips.
Step 6: Load and Fire Away!
Picture of Load and Fire Away!
All Done! You're ready to fire away! Don't fire at anyone though. You could skewer someone's eye.
Notes on loading. It may help to wrap a bit of tape around the middle of the bands to
                                 aid placement behind the arrow.
                                 Load the bands first. Pull the bands down and into the clip. Then
                                 insert the skewer arrow through the straw and push into the binder
                                 clip.
                                  Fire by simply squeezing the binder clip ends.
EnderMine634 (author)2014-02-21
AWESOME THIS IS AMAZING BEST THING EVER AWESOME:) :) :)
JZ101 (author)2012-03-08
thanks brow i appreciate your bad but nice ruller crossbow
............. appretiate it homie PEACERS
Adjuster-X (author)2011-07-09
Hi not to be negative or anything I used the extra straw and I cut it half and then I tape it there and I put ammo in as extra .
Hi not to be negative or anything instead of using Wall hooks I used tuner bands
About This Instructable
5,748views
14favorites
License:
More by Temperance:Ruler Crossbow
Add instructable to:
