3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Running .iso Files in VMWare Player
VMPlayer can be very useful, especially for trying out Linux distributions, but while there are lots of the different distros. on the VMWare website available for download I already had a few iso files of Linux hanging out in my documents, but VM Player cannot open straight .iso files, it's run through a .vmx file which executes the .iso file, so you need this vmx file to boot up the .iso file....
Software:
VM-Player (free)
--downloadable from here
Notepad(or other basic text editor)/Kate
Any *.iso file
A .vmx file (there is one available to download here ("resul.vmx"))
resul.vmx875 bytes
Step 1Editing the .vmx File
I downloaded DSL (Damn Small Linux) from the VM-Ware website just to try the player out when I noticed that all it was was a plain *.iso file with the *.vmx file, double click the *.vmx file starts up VM-Player and then boots the *.iso .
A lot of files can be edited with notepad (or similar program) including this vmx file...
-Right click on the *.vmx file and choose "open with">"notepad".
(Second Pic.)
The ninth line is the only line of text that needs editing, this tells the player what *.iso file to open for booting....
Now put the *.iso file you want to boot into the same location as the *.vmx file, mine are all on Desktop. Select the *.iso file you want to boot (in my case Fedora Linux) then press F2>Ctrl+C which copies the files name. ;-) then you can just un-select the file. (Picture five)
Now go back to Notepad and select the File name, Do not select the quotations too >Refer to image four. Then press Ctrl+V which will paste the file name you copied earlier.
15 comments
Aug 16, 2011. 2:06 PMtaronson says:
I am using it with Fedora iso. I get "No DEFAULT or UI direcftive configuration found".
Apr 7, 2009. 3:56 AMhoyusnd says:
thx so much~! it was really easy following your instruction :-) now i'm installing fedora 10! i found this instruction is compatible with Fedora 10 on VMware Player 2.5.2! good luck!
Mar 30, 2009. 7:07 AMraty2071 says:
i tried to install xp-service pack 3.after sometime it said "did not find any hard disks drives installed in your computer... set up cannot continue" any suggestion .... please email me at ratan.thunderstrike@yahoo.com thanking u for any help....... bye
Mar 13, 2009. 10:09 PMUbuntuNinja says:
I tried to download the "resul.vmx" file but it doesn't work. It comes up with a download window but it wants to download this .tmp thing and not the vmx file.
Mar 14, 2009. 2:16 PMUbuntuNinja says:
does the ISO need to be in the same directory as the .vmx file?
Mar 14, 2009. 2:13 PMUbuntuNinja says:
ok. thanks. can you boot the ISO and then install it to a vmware disk?
Oct 22, 2007. 6:23 PMLinuxH4x0r says:
Yeah Linux!!! But really get rid of that windows in the background. I like it! The box said vista or BETTER, so I installed LINUX!!!!!
Mar 14, 2009. 2:19 PMUbuntuNinja says:
Nice. "Vista or better". Yep. Linux is definitely better.
Aug 5, 2008. 6:16 PMfunyson says:
Hi al
I'm new with VMWare stuff. But i did folowing u people instruction. However, i still can't make it run on VMWare player
The screen of my VMWare player said "
Network boot from AMD Am79c97oa
Copyright (c) 2003-2005 VMWare, Inc.
copyright (c) 1997-2000 Intel Corporation
Client Mac ADDR: 00 0c 29 86 ab f9 GUID: 564dc93d-93b2-daoe-51db-3e5fe786abf9
PXE-E53: No boot filename received
PXE-M0F: Exiting Intel PXE ROM.
Operation System not found
That's all i got, Are u have any solution help me to solve this problem ---------------- thanks inadvance
u can email me @ dechoi@live.co.uk
Feb 15, 2009. 6:34 AMbillducky says:
I was able to overcome this by switching the physical CD-Rom and ISO "cd-rom" in the master/slave settings. For instance, in the cdrom setup area of your vmx file, switch the IDE1:0 of the physical cd with the IDE1:1 of the virtual cd. Worked like a charm!
Aug 6, 2008. 3:54 PMfunyson says:
Yes! It's work for me as long as installation progess start ---then i cna't install it! do u have any ideal about this? please help me!
Nov 18, 2007. 2:22 PMgizmondo says:
Good to see some more Linux users! I have to agree with LinuxH4x0r get rid of Windows!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
32
Author:ll.13
