The Legend of Zelda: Rupee Engagement Ring Box
 by Riley Planalp
Contest WinnerFeatured
Hey Instructabots!
I'd like to present to you instructions for building your very own Rupee engagement ring box, which was inspired by the all of the classic Rupees from the Zelda series.  This doesn't necessarily have to be used as a box for a proposal, I just figured that it was suiting to present your girlfriend with a piece of treasure that opened up to reveal MORE treasure!  The total time for the Rupee Box was approximately two days, and only so because of the time required to let glossy paint dry thoroughly.  I was able to make my unpainted Rupee box without paint in about 3 hours, but then again...my garage is pretty disorganized, so you could probably make it faster!
Here are the things you're going to need for the entirety of this project: (Don't worry about gathering all of the materials ahead of time. I'll re-list the materials needed for each part on the respective steps.)
Power Tools: VRRRRRRUUUUUMMMMM!!
> Table Saw
> Scroll Saw
> Bandsaw
> Belt Sander (40 or 80 grit sandpaper belt)
> ShopVac (to consume the colossal amount of dust you will generate)
> Drill with a small bit 1/16" or smaller (Optional)
Other Tools:
> Sandpaper (100, 150, 180 grit)
> Clamps
> Flathead Screwdriver (Optional)
> 2-part Epoxy (Optional)
> Super Glue (Optional)
> Scissors
Wood--I used a variety of wood types, mainly because it's what I had lying around. I'll list what I used for each piece...
> 2  3"x5"x1/4" Pieces (Plywood)
> 2  1"x3/4"x5" Pieces (Aspen)
> 2  1"x1"x1 3/4" Pieces (Aspen)
> Soft foam, approximately a 1 1/2" cube.  (I repurposed an old memory foam pillow for this part)
> Small amount of black cloth, approximately a 2" square
> Rust-Oleum Filler Primer http://www.rustoleum.com/CBGProduct.asp?pid=11
> Rust-Oleum Multi-Purpose Gloss Spray http://www.rustoleum.com/CBGProduct.asp?pid=97   I used Apple Red, but you can use         whatever color you'd like
> Wood Glue (Any brand will work)
> 3M Dynatron Glazing and Spot Putty http://3mcollision.com/products/fillers-and-glaze/putty/dynatron-glazing-spot-putty-650.html
> Hinges (I found some great hinges at Menards that I have included a picture of.  The exact hinge style isn't critical...you need only be concerned with the overall size of the hinges.) http://menards.com/main/tools-hardware/builders-hardware/door-window/residential-hinges/5-8x1-decorative-hinge/p-1475524-c-9687.htm
Protective Equipment:
> Safety Glasses
> Ear Plugs/Muffs
> Dust Mask (when working with the belt sander)
> Pencil
> Ruler
> X-acto Knife
So, without further ado, let's get on with some step-by-step instructions for building your own Rupee engagement ring box!
Step 1: Assembling the Box
Tools Needed for this Section:
> Table Saw
> Sandpaper (150, 180 grit)
> Pencil
> Ruler
> Clamps
> Wood Glue
Materials Needed for this Section:
Wood:
> 2  1"x1 1/2"x1 3/4" Pieces (Aspen)
> Safety Glasses
> Ear Plugs/Muffs
To begin making the Rupee ring box, you're going to need to first cut all of the wood pieces listed in the Materials section.  On both of the 3"x5"x1/4" pieces, do your best to carefully replicate the plans I have included using a pencil and a ruler. Then the box will be ready to assemble.  Since the completed ring box will have an inner section for the ring, we will make the starting box with a hole in the center, covered on both sides by the 1/4" piece.  Start with one of the 3"x5"x1/4" pieces and glue the 2 1"x3/4"x5" pieces flush with the edge of the 1/4" pieces.  Make sure the 1/4" piece is plan side down!  Next, glue the 1"x1 1/2"x3/4" pieces on the upper and lower parts of the 1/4" piece, between the 2 1"x3/4"x5" pieces, leaving a 1 1/2'' gap in between them.  Allow the five pieces you have just glued together to dry (15 minutes maybe?), before gluing the final 3"x5"x1/4" piece on top of the 'box".  Make sure you glue the final piece with the replicated plans facing upward, as we will use these for the next several steps.  Use your clamps to make sure that this glues tightly on to the 'box'.  Allow this another 15 minutes or so to completely dry before moving to Step 2.
The picture below has a large red "X" to denote where the hole was located on the box.  I was slightly paranoid of accidentally sanding too much or cutting away too much material and accidentally revealing the hole.  I would suggest at least using your pencil to mark off the area where your hole will be as another way to gauge the shaping of your box later on.
jfranks529 says: May 23, 2013. 6:52 PM
I would pay you to make this!!
16lundgcodm says: Apr 17, 2013. 2:55 PM
It doesnt say how to hollow it out!
wackyjackie123 says: Feb 27, 2013. 4:45 AM
if she says no to this she wasnt right anyway
scream__dc says: Sep 23, 2012. 7:54 PM
You're a genius !!!!!!!
arpoky says: Jul 30, 2012. 11:07 PM
Just seeing the finished Rupee Box inside the Chest gave me an idea.
Make a ring box that looks like the Chest from LoZ, and then make a ring with a Rupee instead of a diamond (or go to Crater of Diamonds State Park in Arkansas, find a rough diamond big enough [Good luck with that!], then have said rough diamond cut in the shape of a Rupee.)!
Eluinn says: Jul 19, 2012. 11:30 PM
(removed by author or community request)
Dusk Shadows says: Apr 24, 2012. 10:40 PM
are you married?
if you are did you use this?
Riley Planalp (author) in reply to Dusk ShadowsApr 25, 2012. 10:02 AM
Haha, not yet!
I was commissioned to build a guy, who planned to propose to his long time girlfriend, a treasure chest that would open up to reveal a Rupee. We got to talking and I drew out some plans for a Rupee that could actually open to house her engagement ring. I ended up installing a strong magnet into the back of the Rupee, and making a stand that could hold the Rupee while the box was open.
Also, she said "yes". So maybe I should edit it to say that it has a "100% Sucess Rate" !
Dusk Shadows in reply to Riley PlanalpApr 25, 2012. 8:18 PM
lol great i might try it one day with a spiecal friend =)
Penolopy Bulnick says: Mar 13, 2012. 12:12 PM
This is so cute and creative! Wonderful idea for a ring box :)
cannibal_hect0r says: Mar 12, 2012. 1:13 PM
This is fantastic, you really did a great job!
TheShabz says: Mar 12, 2012. 11:44 AM
Awesome idea. Wonder if you could reuse the hinge from another ring box that snaps the case shut and holds it open. When she says "yes," you can cut the bottom at an angle and attach it to a mount to show off.
falcotheimpaler says: Mar 12, 2012. 11:08 AM
Only 20 rupees? lol
jessyratfink says: Mar 12, 2012. 10:45 AM
This is absolutely the best box you could ever put anything in. My boyfriend should probably see this.
abmat says: Mar 12, 2012. 10:16 AM
I have to say seeing this made me geek out a little. I'm not sure why no one had thought of it before, so hats off to you. Excellent job!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
