Rustic firewood rack by alanwbaker
Step 4: Cut the spacers and top braces
1. Set the four bookends into their final position and level them up.
2. Select four spacer logs about the same diameter as your horizontals.  Cut them to length and lay them between your bookends.
2. Select two top brace logs that fit the V notches. Cut them to length (about 20").
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
