Rusty Junk to Useful Stuff EASY With Chemistry!
92,064
860
85
Published
Introduction: Rusty Junk to Useful Stuff EASY With Chemistry!
About: Hubby and I have given up the ordinary in order to live and travel full-time in our vintage motor home. Our St. Bernard dog and 2 kitties travel with us, as we slowly amble along the back roads of America l...
Backyard DIY Electrolysis for Rust Removal on Cast Iron and Tools
I'll bet everyone reading this has a secret stash of rusty something-or-other; Granny's Dutch oven, tools left in the rain, a cool garage sale find. If only there was some quick and easy way to return the metal to bright and shiny...
There is. Here's a sweat-free, pain-free method of removing every particle of rust from your rusty junk- using the miracle of electrolysis and some random stuff you probably already have laying around.
Step 1: Equipment for Your Miracle
Here's what you need:
An automotive battery charger, 10 amps or bigger. A smaller trickle charger will work, but it might take weeks instead of hours to remove all the rust. One with a built-in ammeter is best, so you can tell when you have a good connection.
A plastic tub, bucket or container, big enough to suspend the rusty article completely free of the sides and bottom; you want the solution to circulate freely. You can also line a cardboard box or basket with plastic to hold the solution- anything will work if its sturdy enough and can be lined in plastic
Arm & Hammer WASHING Soda (not baking soda). You'll find this in the laundry detergent aisle.
Steel for the anode- rod, sheet, bar, whatever you have handy or can buy cheap. Old metal junction boxes, pieces of rebar, literally whatever you have. The more surface area the better.
A non-conductive rod to suspend the rusty article from. I used a piece of CPVC pipe, but wood is good too.
Some wire, any kind
Step 2: Safety First
Do this outside, please.
You will be generating some hydrogen gas and you don't want any explosions in the garage.
Step 1) Fill the plastic container with a measured amount of water- when filled, you will add 1 Tablespoon of washing soda per gallon of water; stir to dissolve. Tip- make the last gallon you put into the tub HOT water, you can dissolve ALL the washing soda in the hot water and you'll get a fast, thorough dissolve.
Step 2) Place the non-conductive rod across the top of the solution container, and wire your rusty article to is so your article hangs completely submerged, but not touching the sides or bottom.
Step 3) Place your anode steel in the solution (the anode can touch the sides and bottom, and it can stick out of the solution too) but make sure it is AT LEAST 2” from your rusty article. Any closer and you will pull too much current on your battery charger and might damage it.
You can use more than one anode, such as multiple pieces of rebar on different sides of the rusty article, as long as all the anodes are electrically connected, i.e. wired together. Using more than one anode speeds up the electrolysis, and you won't have to move and turn your rusty piece during the process, but use whatever is easiest for you. You can also do more than one rusty article at a time, as long as- you guessed it- they are electrically connected to one another and nothing touches.
Step 4) Connect the BLACK clamp of the battery charger to the rusty article, and the RED clamp to the steel anode, and turn on the charger. You can use an extra alligator clip jumper if that makes a better connection to the piece than your regular clamp.
Turn the battery charger on and check the ammeter to see whether or not its “charging”- if not, you may have to scrape a clean spot in the rust so you make a good electrical connection.
Let 'er rip!
Step 3: Making the Magic
You will see bubbles start to form almost immediately, and an ugly rusty sludge will collect on the surface- all normal.
Every so often, turn off the charger and lift out your rusty piece to inspect how the rust removal is going; take this opportunity to turn or invert the piece if you are using a single anode, to make sure all parts are getting blasted.
The length of time you will have to leave your rusty article will depend on how rusty it was and the amperage of your charger. It will probably take a few hours, maybe overnight to totally remove the rust. It won't hurt anything if the charger continues to run, but it won't help either.
You can dump your rusty, sludgy water on the garden, or save it for your next rust-removal project. * note; if you used a stainless steel anode, you may have generated some semi-toxic byproducts; better to not dump this down the storm drain or into your vegetable garden.*
Step 4: Yes, You ARE a Genius;
When you remove your work piece the final time from the solution, you will have noticed that instead of rust, your piece is now covered in a sooty black oxidation layer. The easiest way I've discovered to remove this is with 3M Brand GRAY Finishing Pads, available at Lowe's in the sandpaper aisle, but if you need a more polished surface, you may have to work with the softer white scrubbies. It only takes a few minutes to remove the black stuff.
And voila, you have resurrected Granny's Dutch oven with the expenditure of just a little bit of money and the time it took your cauldron to do it's bubbly electrolysis magic.
Take a bow!
Step 5:
Step 6:
Before and After Contest 2017
Runner Up in the
    • Pets Challenge
      Pets Challenge
    • Casting Contest
      Casting Contest
    • Stick It! Contest
      Stick It! Contest
    85 Comments
    I used this process yesterday on a handful of long-rusted tools. The Washing Soda was tough to find locally but a web search showed that Walmart had some, and they did. Next, my "smart" car charger wouldn't push voltage through what it determined was clearly not a battery. Instead I used a desktop variable DC power supply that I had used to drive an old ham radio--it worked great even at its max of about 16V and 5 amps. I coated all the fresh steel with ACF-50. Great Instructable!
    Were those diagonal cutters frozen tight? I have several tools like that that are rusted inside the joint. Naval jelly does not penetrate there. How does this do?
    I would be interested to know that also. I have had some success by soaking frozen tools in BP Blaster for a few days. Or I soak them in The Works toilet bowl cleaner, it is liquid not a paste like Navel Jelly, it is a fairly strong acid so some safety precautions are necessary and a baking soda rinse once the tool is cleaned and oil of coarse. I also heat the tools to dry them rapidly then coat with oil as they start to rust rapidly after the acid bath.
    If you are looking for a penetrating-type oil, brake fluid works better than almost anything at loosening stuck bolts.
    I never thought to try brake fluid. Especially after what I seen what a spill can do to a car if not cleaned up promptly. There are all sorts of home concotions like 50/50 mix of acetone and automatic tranny fluid, another is to heat the part enough to melt candle wax into the joint.
    ATF and Acetone is a myth. They DONT mix. They are like oil and water and separate within seconds. Cant be done. I tried it and you just cant mix the two.
    It also works to recondition black plastic parts like fender flares, brake and clutch assemblies on motorcycles, anything that the sun has eaten up.
    Yes, if you leave them in long enough (overnight, or a day or so), it will totally remove all of the rust and unfreeze them. I have had parts that were completely jammed to the point that I couldn't close or open them with extreme force. After letting them soak for a few days, they were like new.
    The best part of this process is that it will only remove the rust, not the good metal. If you're worried about soaking something that's heat treated (because you could develop hydrogen ions in the metal), just place it in an oven @ 400 degrees for an hour after treating.
    Here is a trick I try when 'pinchy things' (technical term) are frozen shut...
    First, dip them in some diesel fuel for a little bit. If that doesn't work, stick them in some fine sand or other grit. With some muscle and luck, I've haven't lost yet!
    Yes, they were totally rusted together and impossible to move. Worked freely once out of the electrolyte solution.
    Two ways to free up
    Blowtorch on one half of the box joint then penetrating fluid, white sprit or WD40 - keep gently working the joint and it will go.
    The other way is to freeze one half - commercial product or plumbers pipe freezer spray, plus the lubricants as above
    I have used this technique for years, but in a slightly different fashion...
    I use lye in the water to form the electrolyte, and a large (approximately 40 gallon) plastic barrel, and a 36 volt golf cart battery charger. Same process, just on a larger scale. Any water soluble substance that allows the electricity to flow can be used to form the electrolyte, but some can be quite toxic. The washing soda idea is something I am going to try. Lye can be hard to find these days.
    Care needs to be taken with the lye, but the solution is not strong and I have had no problems with chemical burns. Of course, whenever I come in contact with the electrolyte I wash my hands immediately. And don't wear any clothes doing this that you are fond of. And take off any metal you wear, rings, watches, etc.
    Rebar works great as an anode, but the rust flakes soon coat the bar and reduce the effectiveness of the process. Depending on the size of the project - say, like the cargo rack from a 4-wheeler - you may need to replace the anode more than once. I keep a few pieces of rebar handy, so I can replace one and clean up the other. I hose the crusty used anode off thoroughly - rubber gloves help, remember the lye - and let it dry. Once dry, a wire wheel on a bench grinder (or drill) makes short work of producing a clean "new" anode. You will be generating a significant cloud of red dust, I wear a simple face mask. My shed isn't exactly "tight" - more like a small pole barn - so I do this indoors, but it's best done outside.
    You will be surprised at how fast the rebar will erode. Apparently, the iron rust being dissolved by the electrolysis process takes iron from the anode to form the rusty fuzz on the rebar. I'm sure a chemist out there will have something to say about that. Of course, I'm using about 40 volts and several amps...
    The reason for hooking the red positive clamp from the battery charger to the anode stems from the fact that electricity actually flows from the negative terminal to the positive. Hook this up backwards and you will end up with a shiny piece of rebar and granny's dutch oven will be coated with rusty flakes!
    By the way, protect the cleaned metal surface asap. This electrolysis process leaves elemental iron exposed to the air and it will start to rust faster than you might believe. Also, this process does NOT remove paint. Anywhere that the paint has separated from the metal surface will bubble up and is easily removed, but you need to plan on removing paint if you are going after that "new" look. Speaking of looking "new"... this process does not remove or fill in rust pits in the metal. It only removes the actual rust.
    A final note: I drain the old electrolyte solution on the ground. It's a weak base, further weakened by the water used to rinse the tub. The weeds behind my shed seem to thrive on the stuff. And I only do this a few times a year - once you get past the experimental stage where you want to "derust" everything in sight, you find that you get interested in other stuff!
    I have seen YouTube videos that people used Vinegar to remove rust. No electrolysis. very clean and as you said, rusts very quickly after the part is removed from the vinegar. Need to apply a thin coat of oil to protect it.
    I use vinegar for rust removal all the time. Best part is that it requires no electricity and in the end, you just have rusty vinegar (no other chemicals, I believe.) I've always wondered if electrolysis is better, faster, etc. One day, when I have two items fairly equally rusted, I'll have to try a comparison.
    Vinegar plus DC does the trick! I've cleaned little bits and bobs with vinegar and a 9v battery. Kills the battery in no time but it's very rewarding in a Victor Frankenstein fizzing stinky process kind of way.
    Vinegar works good, it's acidic. The standard white vinegar is about 4% acetic acid, pickling vinegar 7% and I've found at our local Home Hardware store 10% Cleaning Vinegar. I had some 20% from a mayonnaise factory and it would strip the shale off hot rolled steel overnight.
    Good post. I researched the electrolyte situation a few years ago. There was a chemist from the US advocated Arm & Hammer, but with lye added. Not much, but it did make a difference. The power supply, if it is a battery charger, will not deliver very 'clean DC. It needs either a capacitor, or, better still a battery in parallel to smooth the output. You'll find the voltage and current available will be greater. A fuse, in case of shorts is desirable, but a pain to keep replacing when setting up the system. I use a couple of high wattage bulbs instead. When it shorts, the lghts take the current, that's all.
    Wikipedia:
    "Lye" is commonly an alternative name of sodium hydroxide (NaOH) or historically potassium hydroxide (KOH), though the term "lye" refers to any member of a broad range of metal hydroxides." Highly alkaline substance
    any salt will do - the alkalinity means it has spare ions (OH-) to aid current flow. Table salt is Chlorine based so will give off chlorine atoms which will become gas (not so good for you) or bond with the water to give HCL which is hydrochloric acid - which will eventually neutralise the base alkaline solution (all the acid Hs join the base OHs to make neutral H2Os).
    So Baking soda is a good readily available alternative and not as strong or dangerous as Lye (NaOH). Its actually NaHCO3. WHich releases CO2 rather than Chlorine in the reaction. (Still acidic so eventually will neutralise the solution. You'll know - it will stop working. So what you tip out is basically neutral (pun intended)).
    This is why baking soda and Vinegar Lava volcanoes is considered a safe experiment for children to do.
    If substituting lye for the washing soda, what mix ratio would you use?
