Step 3Connecting to the TV
Step 1:- I used a bit of double sided foam tape to stick the RJ45 terminal in the box. I originally tried to connect the terminals in the same way as I had on the PC end but I found that working in the box was too tight so I stripped a bit of network cable and soldered it to the RJ45 terminal.
Step 2:- I then cut a bit of strip board and attached my jump leads on the one side and my AV cables on the other side
I then taped around the box and was ready to plug it in.
My Patch cable is 10 meters long and runs around 3 walls between the TV and the PC.
Add Comment
