3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
S-Video to RCA Connecter
How to build a computer to TV converter or s-video to RCA
originally from link
Sorry i decided to make this instuctable after i made the converter
Step 1Get Your Parts
Get Your Parts
An electronics store should carry all of these parts but your store may not.
1.S-Video connector link
2. RCA connector and cable ( I salvaged mine)
3. 470pf ceramic capacitor (I already Had One)
4. Wire
5. Solder
6. Soldering iron
41 comments
1-40 of 41next »
Jul 25, 2011. 5:58 AMhd. septian says:
Picture Just wite & Black, what should I do?
Oct 17, 2011. 8:57 PMrbneville says:
If your video is b&w then you used the wrong wire. Look here http://moviespics.wcgame.ru/s-video-pinout.html
If you use pins 3 and 1 you will get b&w.
If you use pins 4 and 2 you will get color.
Jul 11, 2011. 11:51 AMprashantchordia says:
I have a problem it displays Black and White picture only not color please help why ??
Jul 18, 2009. 3:24 PMScubaSteve says:
Can someone please tell me why i need a capacitor? ive seen this done without a capacitor, and it dosent seem to hurt anything
Jun 26, 2011. 9:04 AMopenidordie says:
We work on Polycom Video Conferencing units and if you have an auxilary video source that you would like to add to the system. You need to connect it to the S-Video connection. The same happens as with "GAUZZ". Due to the Y and C not being fused together properly. I'm not sure if the cap will work, but I'm curious to try it. We recommend that you use a scaler instead of this cable. Even though we've seen it work.
Eric
Jun 4, 2011. 1:00 AMdkumar4 says:
where to plug rca connector
Mar 19, 2011. 11:09 PMkane89 says:
does it matter the voltage of the 470pf ceramic capacitor
i have found a few on jameco.com but not sure which to get
Dec 27, 2010. 7:02 AMfirebirdfantom says:
could a electrolytic capacitor be used in place of the ceramic?
Nov 19, 2010. 8:28 PMleifforrest says:
There are lots of mini-din connectors, S-video is a 4 pin. See this wikipedia link for a run down.
http://en.m.wikipedia.org/wiki/Mini-DIN_connector
Oct 8, 2010. 7:29 PMgauzz says:
Helpp please!!!
I did a cable without the capacitor but it only works for less than a second, then everything goes black.
Do you believe if I use the cap it'll work? Also in what kind of electronics I can find one? I cant find a place that sells a pf anything.
Oct 15, 2010. 5:22 AMgauzz says:
So... I finally did it, the cables were not connected well so I fixed it without the need of a capacitor.
Thanks!!!
Jun 21, 2010. 7:15 AMmountaindave says:
Worked for me without the capacitor as well.
Feb 11, 2009. 11:39 AMabadfart says:
hey dose anyone have the coding for a VGA cable
Feb 6, 2010. 1:32 PMn0ukf says:
Do you mean the pinout? See Hardware Book.
Aug 13, 2009. 5:18 AMSquink81 says:
Hi, I have made my 4 pin S-Video to Composite...I think thats what it is....cable but I have to test it yet...I am catching up to all the ideas I got from here on Instructables...lol, I am having a great time...fooooooood!
Aug 11, 2009. 11:48 AMTCPMeta says:
All you need is Pins 2 and 4. Ground and Color (Chrominance). Pin 3 is for gray scale video. So with people using 2wire cables just put red to RCA Data and white to RCA Ground. The capacitor is not needed but it helps to clear up the picture a bit, kinda like a weak drop amp.
Jul 14, 2009. 9:57 PMkidapx says:
I have also run into the same problem as jbulldog my S-Video only has 2 wires, a red and a white and inside each wires is another wire. Any idea which would work as ground and which works as the video feed???
May 26, 2009. 9:59 AMlotusomega says:
don't need a Capacitor it´s work whit out it
Feb 28, 2009. 9:01 PMSquink81 says:
DANKE!
Apr 22, 2009. 12:15 PMschnellboot says:
are u german?
Mar 3, 2009. 1:47 AMrcbally says:
is it possible to do the 7pin to give comp video and audio on RCAs, if so how?
Feb 12, 2008. 9:27 PMitstemo1 says:
Do it work the other way around? RCA to S-Video?
Feb 20, 2009. 1:21 PMbombmaker2 says:
probably
Nov 7, 2008. 5:48 AMSedge15 says:
Hey, I'm assuming most of you here are from America? What with the Radio-Shack and all! Just wondering how common a 9 Pin S-Video Cable is over there??? EMPHASIS on the 9!!! lols I'm from Australia and for the life of me can't find a 9 pin! On to my main point!! Awesome Instructable, have tried a similar thing except with 9 pin. failed epicly. So yeah, if 9 pin S-video is common over there would be grateful to know!! Sedge
Sep 9, 2008. 8:34 PMjbulldog_11 says:
I have a radio shack s-video cable, and it has a red and wire only, and then a pink inside the red, and a clear inside the white. Do you happen to know which cable is which?
Jun 12, 2008. 2:14 PMmaxpower49 says:
does this work for pc or does it only work for laptops
Mar 5, 2008. 6:04 PMDIY Dave says:
do they sell that capacitor at radio shack?
Apr 15, 2008. 6:47 PMacaz93 says:
They do , they are in a drawer
Apr 15, 2008. 7:26 PMDIY Dave says:
Thanks, I'll get 1 tomorow.
Apr 18, 2008. 5:52 PMDIY Dave says:
just finished it this evening
Apr 18, 2008. 6:06 PMacaz93 says:
it worked all right ?
Apr 23, 2008. 6:47 PMDIY Dave says:
yes, it worked
Apr 23, 2008. 7:08 PMacaz93 says:
coool
Apr 15, 2008. 6:46 PMturner22 says:
Could you make this with an ipod cord? And if so, how?
Feb 4, 2008. 6:04 AMstxera says:
thanks for the instructions, I'm yet to salvage a capacitor that works.. it does work without a capacitor - but I'm not sure its best that way.
Jan 8, 2008. 10:56 PMmunchman says:
It would be easier, cheaper and safer just to buy one...
Dec 25, 2007. 12:32 PMvanmankline says:
Through other sources I've found 400 pf - 10 nf capacitors would be acceptable (with ~470 being ideal). However, I have been unable to find any. Do you have any suggestions as to where I might be able to salvage one from?
Dec 10, 2007. 3:03 PMhondagofast says:
I didn't see the schematic at first, but this is a very useful instructable. +1!
Dec 9, 2007. 6:20 PMpaulgeering says:
Would I be right in thinking that this will only convert an s-video signal to composite video but will not convert in the other direction (composite -> s-video)?
Dec 9, 2007. 7:30 PMZava says:
You would be right, it can step down the video quality from an S-Video signal to a composite one, but it can't step it up, a composite video connector simply can't accept the higher quality signal. Good instructable, and good idea for a project, but I would suggest some background information into the functions of composite and s-video, and maybe discussing how it will effect the video quality more in depthly.
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:de-evolution
