Step 6In the oven
have to move the project to get it in the
oven. Lay the sheet of foil on a cookie pan
so that it will not tip over in the oven.
You can use water to make the ears tails
and other body parts to stick.You can use
craft glue to attach cocktail umbrellas for a
cute effect.(If your project needs a little
help staying up,use wads of foil to prop
it up in the oven.
BAKING
Bake salt dough projects for 1 to 4 hours
at 200 degrees.
Projects should stay in the oven until hard and
dry.Larger projects will take longer than smaller
projects. Remove the pan and projects with an oven
mitt. Let cool.
6
comments
Add Comment
dombeef
says:
dombeef
says:
dombeef
says:
Add Comment
