SAVAGE Mod for Streamline Nerf Darts
2,594
9
Posted in PlayNerf
Introduction: SAVAGE Mod for Streamline Nerf Darts
Oki so i was messin round with the darts and i was gettin proper pist off at the darts wag tailing it out of the gun( when the back end of the dart spins taking speed off the dart).. I pretty much put it down to the weight of the tip not been heavy enough so i was left thinkin how do i weight the dart without shredding it up. I wanted to continue usin the darts in the clip, so i wanted to leave the darts intact as much as possible.
Now eres what i came up with, by the way ive used this mod in the recon, long strike and nitefinder and it works class
recon (has the air restrictor drilled out)
long strike (as above)
nitefinder (is factory set)
((ALWAYS CHECK OUT THE FIRST DART MOD TO MAKE SURE YOUR HAPPY BEFORE YOU DO ANYMORE))
Step 1: Before Mod
Oki so eh i decided to use was basically fishing weights,  the size i used were .8 g , and ya can pick em up in any fishing store for 1 euro 50 cent ere,  and fixed up 24 darts with the lot..
Step 2: Whats Needed
with the size pellets i bought ( forgot the nerf dart for size measures) i managed 2 pellets in the tip of the dart without deforming the tip too much, now you'll notice the tip is a bit bumpy around the sides when ur finished but not enough to snag in the chamber. If you want you can use bigger pellets prob twice the size of the .8 s... so 1.6g will fit snug, or if you wanna use smaller ones and make buck shot darts then work away just make sure there not so small that they fall out the whistle hole(unless you wanna use glue to seal the hole)
Step 3: Gettin It Done
Ok this bit is a bit fiddly but after the first 4 or 5 darts youll get the hang of it..
What i used was a narrow tip scissors to pry the whistle hole open to allow the pellet to be
pushed into the dart tip...
1. close the scissors and insert into the whistle hole
2. slowly open the scissors to make the hole big enough for the pellets
3. take your first pellet and close the slit (theres a slit in the pellet so it can be clipped to the fishing line)
    making the pellet smoother.
4. slip the pellet into the hole and repeat to get the second pellet in , then remove the scissors and massage the dart tip so the           pellets are settled and wont be falling out .
Step 4: Your Finished Bullet Mod
Well this is the finished dart..
I have no idea if this has been done before i aint seen it on the net so if you aint heard bout it well try it out and let me know what you guys and gals make of the mod :)
ENJOY
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    you can also use copper bb's
