3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SCR Tester from a Flashlight
I design and test high power equipment that uses large SCRs (silicon controlled rectifiers). Sometimes one will go out.  I use 6 in a three phase bridge configuration and if one goes out, its difficult to find the bad one without taking them all out. You can make a "in circuit" tester out of a flashlight.
Step 1What is an SCR?
What is an SCR?
An SCR is a Silicon Controlled Rectifier.  They are used in power supplies, welders, inverters and other equipment for controlling power. The one below can carry 350 amps of DC current with a rating of 2400 volts.  Think of them as a diode that can be turned on with a small current to the gate.  Once turned on, they stay turned on till the current flow is interrupted or below the minimum current. Large SCRs like this one requires 150 milliamps at 3 volts to turn on. The SCR behaves like a solid state latching relay.  The large base at the left is the Anode and attaches to a heat sink.  The "pigtail" end at the right is the Cathode and the white wire is the Gate. The additional skinny red wire is connected to the cathode and is used with the gate when connected to a triggering circuit.
6 comments
Oct 11, 2010. 7:47 PMharrisonharrison says:
That's a great experiment! i have a 3W 160 lumens LED Flashlights, is it suitable to experiment?
Oct 14, 2009. 9:46 AMinventorjack says:
I recently obtained a couple large SCRs that look just like the ones inyour instructable. They're labeled "GE C55B", but I couldn'tfind any information or datasheet for them. Do you have a similar model,and if so, do you have or know where to obtain datasheets for these?
Thanks for any help you can provide!
Oct 14, 2009. 10:28 AMPhil B says:
Thank you for a well-done, useful Instructable; even though I do notwork with large SCR's.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
68
Author:botronics
I like to tinker and experiment with electronics, robotics, programming, and photography
