3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SD Card Adapter
SD Card Adapter
This Instructable tells you how to make an SD adapter which will enable you to add up to 2GB of memory to your microcontroller projects. It includes a card inserted LED and is used in SPI mode.
A kit inluding all the parts necessary to build the SD Card Adapter can be purchased here. If you wish to do so, you can also make your own version without purchasing the designated kit, but getting the SD card slot may be challenging, as there are many different versions. Purchasing the kit, however, provides much greater support if you have any problems or questions.
This project requires approximately 30 minutes to assemble, and some parts may be a bit challenging to the beginner in soldering.
If you have any questions or comments, feel free to add them in the designated area below.
Without further adieu, plug in your soldering iron and get all the parts together. For those of you who are building your own version, check the link given above and on the bottom left you will find an option that says "parts list." Selecting that will show a menu of all the parts required to make it.
Step 1The Hard Part First....
This is one of the hardest parts of the project because it requires some "surface mount soldering." (note the quotations) Now, follow the steps shown in the image notes in order to get the SD slot on your PCB.
16 comments
Oct 8, 2010. 6:46 AMdracogold says:
very good project , congratulations
Dec 23, 2009. 12:58 AMnavaraj says:
Will you Please give the details of the pin outputs and how to use with Microcontroller ?
Dec 28, 2009. 9:00 PMnavaraj says:
AT89S52
Aug 20, 2009. 5:01 AMflorinc says:
You could have also added the 3V3 regulator.
Jul 15, 2009. 1:53 AMmicroman171 says:
File system? How would I go about adding a file system...? It would make interfacing with the computer nicer. Even if I had to create a file on the computer, for the uC to write to.
Jul 15, 2009. 12:30 PMmicroman171 says:
I can use either an AVR or a PICAXE 28X1. Both are capable of SPI. A filesystem is what a computer uses to arrange files. Without it, the data wouldn't have starts and stops, it would just be a big EEPROM. What I want is for the uC to be able to write to one of these files as if it were a person typing data then saving.
Jul 15, 2009. 5:20 PMmicroman171 says:
No code just yet, I'm in the concept phaze, and an SD card is an option. A mate of mine suggested an XD card, but I'm not too sure, as I don't have one. FAT16 would be great, I'll do a bit of research on how it all works.
Jul 14, 2009. 6:25 PMHarveyH44 says:
Perfboard, jumpers... ugh , and in kit form. Haven't had need of more memory yet, but have had a few data logging, counter ideas though. Was thinking of just soldering leads to the card connectors. Got a bunch 1 gig or less, that I don't use anymore, so destruction wouldn't bother me. Socket would be nice though, make it easier to get data into the computer later...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:vaati(Gameboy Development Stuff)
