SD Card Carrier
1,383
6
Posted
Introduction: SD Card Carrier
I, like many here, am always on the hunt for the perfect thing to solve a certain problem.  My latest "want" was a compact  case(s) to carry my camera SD cards when traveling.  I tend to stick with a lot of 4GB sized cards, which each will hold (for me) a days worth of vacation shots.  I don't travel with a laptop or even care to download the pics every day, so by swapping out cards regularly, the entire vacation isn't on one card - and susceptible to one accident away from losing the entire photographic collection.
So what to do with a dozen cards when on a 7 night cruise and OCD enough to want to pack as lightly and compactly as possible?  I could not find a high capacity compact case for just SD, they always seemed to have extra sleeves/slots for sizes I don't use, and were bulkier than I cared for.
I can sew, and have made some foam/fabric ones before, but they were only bandages, not a cure for my ills.  Lo and behold at the local Big Box store today, in the travel toiletries section, were these little beauties - toothbrush head covers.  It was the little angled notch that intrigued me, so for a $0.97 gamble, I grabbed a pair and headed for home with fingers crossed.
Step 1:
I couldn't believe, but they fit like a glove.  A touch too tight when packing 6 in each one, but 5 is just right.
It is difficult to see, but inside are very shallow ribs - I trimmed them out with a simple wood chisel to smooth the inside completely.  I also used a rotary tool to relieve the ridge on the lid by the hinge so I could be sure it would clear the cards as well.  In retrospect, it wasn't necessary as the lid clears perfectly.
The cards are held with just enough tension to not just fall out, but a light shake drops them into your hand as easy as a vitamin from a bottle.
I'm going back and get some more, of a different color, so the unused go in the yellow, and the used go into the red.  I'm now organized and worry free which cards are which, how many I have left, etc.
The final caveat is these are NOT watertight by any means.  There are three tiny vent holes in the bottom, and the large hole in the lid (where the toothbrush handle would go through).  While the vent holes are easily sealed, the lid is simple not sturdy enough to trust, even if you could find a way to adequately seal the hole in it.
I'm still looking for a waterproof/water resistant solution, so please share if you have an idea.  Thanks for checking out my first contribution!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
2 Comments
Brilliant repurposing idea, and a well-done Instructable! The cards are a perfect fit in a very compact little case. Maybe you could make it water resistant or even w'proof by pressing a thin layer of silicon sealant or E-6000 (very thick rubbery glue) into the ventilation holes. Once it cures it won't stick to the cards. You'd also need to make a plug (could be just a blob of the same sealant or glue, or maybe Oogoo) to fill in the top hole where the toothbrush handle is intended to go through. I think I might have some of these little cases that I can try that with! Thanks for sharing!
Clever!
