3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SD/MMC fits in floppy edge-connector
  • last photo ←
You can attach an SD camera memory card to any homebrew DIY project that has a few I/O pins,
using ordinary connectors you probably have right now.
For more details, how to obtain free mmc device drivers, and installing various open source Linux distros on WRT54G wireless routers (and other routers and devices), go here:
http://uanr.com/sdfloppy/
This is the finished "SD floppy" connector, which has been running flawlessly inside a friend's wireless router for 6 months now:
Here is the standard PC floppy cable we will use for this hardware hack, with an SD card for a size comparison.
27 comments
May 11, 2010. 6:31 PMmatstermind says:
could this be used to add more memory to an arduino?
Oct 8, 2011. 3:26 AMskaar says:
yah, old post, but... you'd need to have the filesystem driver to use it.
Apr 2, 2011. 3:54 PManilmosses says:
It's very good
Dec 16, 2009. 4:42 AMrogerjowett says:
isnt there a floppy disc that has the sd memory device inside it
can you read and write data
what kind of read write speeds are available please?
does it need a driver?
can you modify zx microdrive cartridge for sd/compact flash also
is it possible to use the motor to power the device/charge any battery required?
what transfer speeds possible from 8 devices?
Nov 17, 2009. 11:00 PMals_liahona says:
Brilliant idea!  I just added a comment in my Instructable (Great idea, great Instructable!  I just added a comment to my own Instructable (http://www.instructables.com/id/Digital-Window-Sticker-Arduino-Controlled/) recommending this as an alternative to the expensive SD Card breakout board I used!) suggesting this as a possible, lower-cost alternative to the SD Card breakout board I used.  I'll be trying this out for future projects!
Mar 12, 2008. 7:29 PMuhsnamih says:
hi nice trick but what does it realy for ....Ooo i understand........well what about if we attach a usb cable on the end of that cord.........well what's your opinion...................byyyyyeeeeee
Sep 30, 2008. 11:58 AMDBLinuxLover says:
well uhm. This is primarily designed for the hack of the Linksys router WRT54G, which allows you to attach an SD card, and have the router interface with it. Then you can run the router with that extra memory. (You could host email server, web server, etc off your router). No usb support. Want a USB connection? you would have to buy one.
Mar 4, 2009. 1:05 PMjamwaffles says:
He he i steal internet off one of those routers :P. Dont live near cambridge do you?
Mar 4, 2009. 11:28 AMcarlos-felo says:
It's very great!
Dec 26, 2008. 3:26 PMcuchulain92 says:
Here's the idea I've got- need to find out if it would work. Use the SD card as the boot drive for Linux, and add it in place of my floppy drive on a desktop: a fast boot, low access time for the OS, less moving parts & less space...
Mar 14, 2008. 8:06 PMuhsnamih says:
hi aaaaaaaaaaa............it was a floppy drive cable right?.........aaaaaaa.........what about if i use a cd drive cable............hhhhhhhhhhhhhhhhhh
Oct 6, 2008. 2:54 PMPopcornfilms says:
you sir. are a cool dude. such wise observations!
Jun 12, 2008. 10:01 PMDerin says:
wont work cd drives use holes as in the left pic floppy connectors(5.25" size)use the suitable connection (right picture)and 3.14 drives use the center connector(admire the smaller number of pins)i cant put up pics now
May 8, 2007. 10:29 AMkhromes says:
i was wondering if this could be used with an old laptop, i'm buying a compaq lte5300{manufactured 1997}, and it has no usb or cd-rom. i would like to know if it is possible to replace the laptop's floppy drive with a SD card? maybe then i could use the SD as its removable storage, would be nice to use a 2gb card, sure beats any floppy disk!
May 6, 2008. 12:50 PMmycroftxxx says:
The basic answer to this is "No", the technical answer is "kinda". This instructable is about using the floppy cable connector as a cheap and probably-around-the-house-somewhere SD card socket, for people who are planning to add a socket to an existing piece of hardware but don't feel like ordering one from a supplier. This cable is meant to be attached to a serial port so that it can be accessed once the firmware of the device (in this case, a wireless router) has been modified. You _can_ do the same thing with your old laptop, but there are better tricks you can try.
Mar 1, 2008. 12:51 PMtwenglish1 says:
how would you hook a usb connector to this??
May 26, 2007. 1:24 AMDieCastoms says:
I did not read the replies so this may already have been said, why not tie the odd pins in the correct order to the even pins so that if you push the SD card in 'upside down' it will do the same thing anyway? Awesome idea by the way, might be useful to me in the future. Mike at DC
Mar 11, 2007. 8:12 AMdognose says:
Or maybe a dual channel one that could be used like a dual tape deck to make copies.
Mar 11, 2007. 8:08 AMdognose says:
Would this work with USB?
Feb 5, 2007. 7:32 PM!Andrew_Modder! says:
I see your using the "skuzzie" side. I wonder if it works with normal side?
Nov 6, 2006. 10:28 PMbostrees says:
Now... Maybe I'm just not thinking this through all the way, but is there a way to do this or something very similar and have it connect to a motherboard via the floppy connector or is this specifically for attaching to the wireless router?
Nov 8, 2006. 9:41 AMbostrees says:
I look forward to that one then :D I don't have anything reliable to solder with right now and unless I can find a few other projects, I'm not about to run out and get something for one project :P
Sep 23, 2006. 10:16 AMMyself says:
Nice photos too, good closeups with nice even lighting. Just when I was considering throwing out my bucket of old floppy cables, someone finds a new use for edge-card connectors! I find it ironic that the connector outweighs the card it's connecting to. If you remember how big the old "full-height" floppy drives were, it's just breathtaking.
Sep 15, 2006. 1:32 PMtrebuchet03 says:
awesome -- I saw this on hackaday not long ago... excellent work
Sep 15, 2006. 11:37 AMbillcd says:
Very cool. Those are my favorite routers. I've got 3 of them. A set of batteries and they will go anyware and do anything! And now with more memory!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:robwen
