Raspberry Pi SHT25 Humidity & Temperature Sensor Python Tutorial
Published
Introduction: Raspberry Pi SHT25 Humidity & Temperature Sensor Python Tutorial
About: We are a group of makers. We work in IoT, IOS app, android app, embedded design, sensor design, raspberry pi, arduino, beaglebone, particle electron, particle photon, Bluetooth.
SHT25 I2C Humidity and Temperature Sensor ±1.8%RH ±0.2°C I2C Mini Module. The SHT25 high-accuracy humidity and temperature sensor has become an industry standard in terms of form factor and intelligence, providing calibrated, linearised sensor signals in digital, I2C format. Here is the demonstration with a Python code using Raspberry Pi.
Step 1: What You Need..!
1. Raspberry Pi
2. SHT25
LINK : https://www.controleverything.com/content/Humidity...
3. I²C Cable
LINK : https://www.controleverything.com/content/I2C-Cabl...
4. I²C Shield for Raspberry Pi
LINK : https://www.controleverything.com/content/I2C-Mast...
5. Ethernet Cable
Step 2: Connections
Take a I2C shield for raspberry pi and gently push it over the gpio pins of raspberry pi.
Then connect the one end of I2C cable to SHT25 sensor and the other end to the I2C shield.
Also connect the Ethernet cable to the pi or you can use a WiFi module.
Connections are shown in the picture below.
Step 3: Pyhton Code
The python code for SHT25 can be downloaded from our github repository- ControlEverythingCommunity
Here is the link for the same : https://github.com/ControlEverythingCommunity/SHT2...
The datasheet of SHT25 can be found here :https://s3.amazonaws.com/controleverything.media/c...
We have used SMBus library for python code, the steps to install SMBus on raspberry pi is described here:
https://pypi.python.org/pypi/smbus-cffi/0.5.1
You can also copy the code from here, it is given as follows:
#Distributed with a free-will license.
# Use it any way you want, profit or free, provided it fits in the licenses of its associated works.
# SHT25
# This code is designed to work with the SHT25_I2CS I2C Mini Module available from ControlEverything.com.
# https://www.controleverything.com/content/Humidit...
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# SHT25 address, 0x40(64)
# Send temperature measurement command
# 0xF3(243) NO HOLD master
bus.write_byte(0x40, 0xF3)
time.sleep(0.5)
# Read data back, 2 bytes
# Temp MSB, Temp LSB
data0 = bus.read_byte(0x40)
data1 = bus.read_byte(0x40)
# Convert the data
temp = data0 * 256 + data1
cTemp= -46.85 + ((temp * 175.72) / 65536.0)
fTemp = cTemp * 1.8 + 32
# Send humidity measurement command
# 0xF5(245) NO HOLD master
bus.write_byte(0x40, 0xF5)
time.sleep(0.5)
# Humidity MSB, Humidity LSB
# Convert the data
humidity = data0 * 256 + data1
humidity = -6 + ((humidity * 125.0) / 65536.0)
# Output data to screen
print "Relative Humidity is : %.2f %%" %humidity
print "Temperature in Celsius is : %.2f C" %cTemp
print "Temperature in Fahrenheit is : %.2f F" %fTemp
Step 4: Applications
SHT25 temperature and relative humidity sensor has various industrial applications like temperature monitoring, computer peripheral thermal protection and so on..
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
