SIMPLE DOORBELL FOR YOUR ROOM
37,483
151
12
Published
Introduction: SIMPLE DOORBELL FOR YOUR ROOM
About: big looser my self
In this Instructable We are going to see the making of simple Door Bell for our rooms,this project is simplest one even made by beginners very well and very cheap .this project costs $1-$2.
Most of them want privacy on their room, this Door Bell may use to avoid the interruption of others. Simply make this project and fix it on your room, this may help to ask the permission to entering by others.
This Door Bell may also used by main Door Bell of the house.
This Door Bell circuit contains two normal NPN transistors (BC 547) and a musical transistor BT 66 T19L.This circuit consumes 3-4.5V.The amount of volume of the Door Bell is increased by increasing the Voltage level.
Step 1: Gathering Tools & Materials
Materials:
NAME RANGE NO
Resistor - 100R - 1
Capacitor - 220uf/25v - 1
Transistor - BC 547 - 2
BT66T19L 1
Speaker - 4 ohm - 1
Wire ----- required
Battery - AA size - 2
Common PCB ------- required
Push Button Switch - 1
Soap Box
Plastic Bush
Small Tic Tac box
Super Glue
Battery Cap
TOOLS&EQUIPMENT
-Soldering Iron
-Soldering Wire
-Hot Glue Gun
-Wire Cutters
-Insulating Tape
Step 2: ASSEMBLING THE CIRCUIT
Mark the required size on PCB board and cut it out.
Assemble the circuit by give plan.
Solder the wire on the terminals of speaker and connect the speaker to the circuit board.
Step 3: MAKE THE COVER FOR DOORBELL
Because of choosing the Soap Box for this project, normally it contains holes on bottom this will help to spread the speaker sound.
Take the Soap Box; this contains two parts top and bottom parts.
We are going to fix the speaker on Soap Box bottom side ( hole side) by using the Glue Gun.
Mount the plastic bushes on bottom of the circuit board by the help of Super Glue.
Take the top part of the Soap Box; place the circuit board on it by the help of Super Glue.
Step 4: MAKE THE DOORBELL SWITCH
Normally the switch of the Door Bell was fixed from long from the bell, so it requires the long wire.
Here I am using the twisted pair of wires you can use any type wire.
Make a small hole on the Soap Box’s top part.
Solder the long wire on the + ve and – ve point of the circuit.
Pass the wire through that hole.
I am splitting the positive wire (red wire),and solder the wire came from the circuit board with the positive pin of the battery cap.
Solder the long red wire with negative pin of the battery cap.
Don’t confuse the color of wire is not important, the long black wire is directly connected to the negative point of the circuit. Now connect the push button switch on the end of wire.
If the switch is pressed the circuit gets closed and the tone was generated
Place the switch on any plastic cover (here I am using the tic tac box as a cover).
Close the soap box and stick it around with the insulation tape.
Now the Door Bell is ready.
Step 5: Working
Place the Door Bell on your room and place the switch outside of the room.
If anyone want asks the permission to enter the room just press the button of the switch and the Door Bell will initiates you.
The working of this Door Bell is super click here to watch the working of this door bell.
This is not my own circuit I just reference the websites for this circuit.
For any doubt on making of this circuit you will directly ask to me.
Any suggestion for this please mentions it with your comments.
SIN Q/COS Q=TAN Q
  • Clocks Contest
    Clocks Contest
  • Woodworking Contest
    Woodworking Contest
  • Oil Contest
    Oil Contest
12 Comments
i have a doubt in it .. wheather both the terminals of the switch is connected to the battery cap....???
how to use um66 in proteous????
hi this item is really cool im still trying to make it
The transistor BT66T19L is not available at our area, please recommend an alternative for it , pleease !
Cool i'm going to have to make this
oh okay than... by the way this project easy for my project.. simple ...
Nice and simple circuit. I was thinking of making it as my project, can you please tell me what is the principle of working of this doorbell?
