3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SIMPLE Parallel/Series Select Switch
In this Instructable, I will explain how to use a simple double-pole, double-throw (DPDT) switch to select series or parallel wiring for two loads on one power source.
Wiring two loads in series will provide the full current available to both loads but only half of the available voltage, whereas, wiring the two loads in parallel will provide each load with the full available voltage, but only half of the available current.
Using this switch can effectively allow you to choose two power settings for your two sources. In the case of light bulbs, this can give you a bright or dim setting, without needing two different wattage bulbs.
In the case of electric motors, this can give you slow.fast and high/low power settings.
This uses the simplest Double Pole Double Throw switch. This requires nothing more than the switch and some creative wiring. Please note that the "off" position only works if you have a "center off" switch! A DPDT relay can easily be substituted if you have one. If you want a 'struct' on this, leave me comments.
Please note that this instructable is intended to go with another of my instructables. Some of this instructable has been copied from my other instructable, since it will use the same type of switch.
You can find my other instructable here:
http://www.instructables.com/id/SIMPLE-Polarity-Reversing-switch/
Step 1Selecting your switch
You need to decide if you want to purchase a switch or salvage one from something else. if you purchase one, you have more options as there are many out there. if you salvage one you are limited to what you can find.
Make sure the switch you use can handle the amount of current you need
Decide if you want an off position or not.
Decide if you want a sliding switch, a toggle switch, rocker switch, or even a spring loaded switch that returns to off when released.
If there is a junk car around, check it for power window switches or electric seat adjusters. Both are most often DPDT switches. Don't forget to steal the motors or sometimes linear actuators out of the seat adjusters, if you can!!!!
Broken stereos commonly have one or two switches in them
If you salvage a switch, the first thing I would do is test ACROSS the switch to be sure it is double pole. The switch has two rows of contacts with three pins per row. NO pin in one row should have continuity to ANY pin in the OTHER row. In the "center off" position, if equiped, NO TWO PINS should conduct.
In the case of a sliding switch: You should find that the center pin in each row conducts to the pin at the same end that the slider is on, but will not conduct to any other pin in the same row or to any pin in the other row.
In the case of a toggle switch: You should find that the center pin of each row conducts to the pin at the end OPPOSITE to the toggle lever, but will not conduct to any other pin in the same row or to any pin in the other row.
In the case of a rocker switch: You should find that the center pin in each row conducts to the pin at the same end of the switch as the RAISED side of the rocker, but will not conduct to any other pin in the same row or to any pin in the other row.
16 comments
Apr 20, 2012. 3:55 PMNokjhnbvtyhj says:
Hi Mike,
Would what youhave described work as a torch dimmer if i were to implement your instructions?
DPDT Relays, - can i use a solid state DPDT to "create" a parallel or series power circuit using only
1 power source and use the DPDT to selct between the 2 at will?
any ideas please,
i am quite a novice,
Thanks for your instructable anyway,
many thanks,
cheers,
tony
May 9, 2012. 6:03 PMjudypalmer says:
Your first instructable, my first time commenting! Wonderful instructable! I'm converting an AC swamp cooler to run on solar panels using two radiator fans. I spent hours trying to figure out how to run the fans in series or parallel (low or high) with a DPDT. By following your directions, I wired it up in about 15 minutes. Thanx, I'll look at some of your other instructables!
Nov 22, 2010. 11:52 PMSnoopKatt says:
Thanks! Worked perfectly. It doesn't matter which side is which BTW, I tested it myself for that.
Nov 18, 2010. 8:23 PMSnoopKatt says:
Thanks! I bought some 6A/125V switches for some guitar cabs I'm building, so I can switch between 4 ohms and 16 ohms :)
Sep 19, 2009. 7:15 PMbennyb1 says:
Will this work on a Jazz bass, to change the pickup configuration? I was going to put in a push-pull pot for this, but have several of this type switch on hand. Thanks for the info. BennyB
Sep 20, 2009. 7:12 PMbennyb1 says:
I believe that will do what I want. It just alters the sound output of the pickups. Thanks. BB
Jul 26, 2009. 12:04 AMPARKOUR123 says:
Does it matter how you hold it? I mean can you hold it the opposite way and still have the same meaning? Also how do you tell which one is pin 1?
Jul 26, 2009. 12:11 AMPARKOUR123 says:
Can you also add a picture of your DPDT slide switch after you have finished soldering as I am a little confused with how to connect it.
Apr 22, 2009. 8:26 PMvarun17 says:
i know that sir but does that mean that we get parellel and series connections in a single switch connection means if we want to connect 2 motors in series and 2 in parellel then that wont be possible.....
Apr 19, 2009. 6:19 AMvarun17 says:
i understood the connections for the off position but what change we have to do for parellel nd series connections i mean what does the green line represent? and sir can u please send me the DIAGRAM when we r using 4 motors and 2 dpdt switches,actually i tried it but the robot didnt work,so please send me the diagram as well.
Apr 20, 2009. 4:19 PMkahles77 says:
the green represents the position of the slide(contacts) in the switch.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:DieCastoms
