i am ajinkya
this is my first Instructable -SIMPLE WATER DETECTOR
For this project u will need the following parts:
1.IC 555 timer-1
2.Small size generel purpose PCB(Single Sided)-2
3.Buzzer-1
4.Red LED(5mm)-1
5.electrolytic capacitor-2.2uF -1
6.Resistor's-R1=1k Ohm
R2=100kOhm
7.A 9v Battery-1
8. Wires(optional)
9.breadboard(optional)
10.Soldering Iron
Also the sensor board is my homemade sensor board made out of generel purpose pcb.
to make this u will need:
1.A small PCB(Single sided).
2.Laser printer(only laser printer is better) & OHP sheet.
3.FeCl3(Ferrus Cloride) PCB Etching Solution.
4.Cloths iron.
Gathered Parts Together?
Ready?
ok.......
Now Look carefully following circuit Diagram & try out the circuit on bread board first.
if it is working properly go to making its PCB version. the PCB for the project is shown here.
The pcbs r homemade here.
If u r new to pcb making then dont worry......... U can make pcb's at home
to learn this pls visit to the link-http://iamsuhasm.wordpress.com/2008/12/10/making-pcbs-the-right-way/
on the SUHAS'S BLOG.
After that fix all the parts on the pcb(not the sensor board) as per the following images & ckt diagram.
Fixed??? Ok Now attach the probes to sensor board & give power supply.
Now drip some water on the sensor board & see what happens!!!!!
U can use these ckt as a automatic wiper starter for u r car by replacing only the buzzer to motor & few ckt changes for continuous motor rotation.
See video on below attachment(the video format is MP4 so use video player which supports the MP4 format)
(Note:TO MAKE THE SENSOR BOARD THE COPPER PCB IS NOT BETTER DUE TO OXIDATION. U CAN USE ALLUMINIUM FOILS/STAINLESS STEEL PLATES)
PLEASE RATE IF U LIKE N COMMENT!!!!!!!!!!!!!!
Now it is bugging me so I fixed the one trace I didn't like.
when water is added in glass then salt water conduct current n buzzer will ring.. :)
And yes.....NPN is there.....
and not a very good idea
Maybe this is not a good idea for u...but good for others and simple
and this is my first circuit when i was beginner to elctrnx and also i am not a electronics student
