SMART GROWING POT(SGP)
4,123
77
6
Published
Introduction: SMART GROWING POT(SGP)
About: new life
HELLO guys!
This is my 1st Instructables project! its called Smart Growing Pot
It is my Finally Year Project currently and i am graduating at the end of this month.
i was notified that i has been selected to participate in a special raffle for a Dremel!
So in this project i will share to you how the project works, and all the development process
Step 1: ​CHAPTER 1 INTRODUCTION
1.0 PROBLEM STATEMENT
- Not enough time for gardening as gardeners are working and having vacation at the same time.
- Unpredictable weather in Malaysia causes gardening to be more difficult
. - Plant does not grew up according to plan and easily died.
1.1 TARGET USER
- Housewives
- Gardener that working and love to go vacation
1.2 OBJECTIVES
- To identify the important elements in gardening.
- To develop a Smart Growing Pot by implementing the identified important elements
- To evaluate the test result from the prototype.
Step 2: CHAPTER 2 METHODOLOGY
Collect requirement from respondents
-interview
-survey
Materials needed
- Arduino Mega
- Breadboard
- Jumper wires
- Wifi Shield
- 3 sensors ( temp , light, soil )
- Resistors
- Speaker
- Plant
- Acrylic glass
-IC Board
Step 3: CHAPTER 3 TESTING
Observation testing
1. Test between Normal vs Controlled condition
- Normal condition : 1 volunteer will take care of the plant normally with normal daily routine ( working)
- Controlled condition : 1 volunteer will take care of the plant with SGP system.
Step 4: CODE
Source Code
#include
#include
#include
#include "SD.h"
#define SD_ChipSelectPin 4
#include "TMRpcm.h"
#include "SPI.h"
#include
#include
#include
int sensor_light = A5;
int value_light;
int sensor_temp = A0;
int value_temp;
int sensor_water = A3;
int value_water;
int red = 3;
int yellow = 6;
int blue = 5;
int green =2;
int pumpPin = 44;
LiquidCrystal lcd(47, 45, 37, 33, 31, 24);
int backLight = 28;
char ssid[] = "LAKEVILLE"; // network SSID (name)
char pass[] = "abcd1234"; // network password
int keyIndex = 0; // network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
WiFiServer server(80);
// ThingSpeak Settings
char thingSpeakAddress[] = "api.thingspeak.com";
String APIKey = "80OVCF5JFVA6H9A5"; // enter your channel's Write API Key
const int updateThingSpeakInterval = 20 * 1000; // 20 second interval at which to update ThingSpeak
// Variable Setup
long lastConnectionTime = 0;
boolean lastConnected = false;
// Initialize Arduino Ethernet Client
WiFiClient client;
TMRpcm tmrpcm;
void setup() {
tmrpcm.speakerPin = 11;
tmrpcm.setVolume(5);
// Start Serial for debugging on the Serial Monitor
Serial.begin(9600);
lcd.begin(16, 2);
pinMode (3, OUTPUT); //red led - temp
pinMode (6, OUTPUT); //yellow led - light
pinMode (5, OUTPUT); //blue led - water
pinMode (2, OUTPUT); //green led - overall health
pinMode(backLight, OUTPUT);
digitalWrite(backLight, HIGH);
pinMode(pumpPin,OUTPUT);
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println(" failed!");
while(true);
Serial.println(" done.");
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while (true);
// attempt to connect to Wifi network:
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the status:
printWifiStatus();
void loop() {
// read values from pins and store as strings
delay(1000);
status=0;
value_temp = analogRead(sensor_temp);
float celcius = (value_temp/5.6);
value_light = analogRead(sensor_light);
value_light = map(value_light,1000,0,0,100);
delay(500);
value_water = analogRead(sensor_water);
//value_water = map(value_water,1023,0,0,100);
// String light = String analogRead(A0); // read light value
String temp=String(celcius);// turn integer to string
String light=String(value_light);// turn integer to string
String water=String(value_water);// turn integer to string
lcd.setCursor(0, 0);
lcd.print("SUN:");
lcd.print(light);
lcd.print(" TEM:");
lcd.print(temp);
lcd.setCursor(0, 1);
lcd.print("WATER:");
lcd.print(water);
// find temp value
//float voltage = analogRead(A1) * (3.3 / 1024); // convert 0-1023 range to 3.3V range
//int tempVal = (voltage - 0.5) * 100; // convert voltage to temperature in *C
//String temp = String(tempVal);
// Print Update Response to Serial Monitor
if (client.available()) {
char c = client.read();
Serial.print(c);
// Disconnect from ThingSpeak
if (!client.connected() && lastConnected) {
Serial.println("...disconnected");
Serial.println();
client.stop();
// Update ThingSpeak
if (!client.connected() && (millis() - lastConnectionTime > updateThingSpeakInterval)) {
updateThingSpeak("field1=" + light + "&field2=" + temp + "&field3=" + water);
Serial.println(light);
Serial.println(temp);
Serial.println(water);
lastConnected = client.connected();
if (value_temp < 100){
digitalWrite (3, HIGH); // plant too cold - red led on
status=1;
}else{
digitalWrite (3, LOW); // normal temp - red led off
if (value_light < 30) {
digitalWrite (6, HIGH); // not enough light - yellow led on
status=1;
}else{
digitalWrite (6, LOW); // enough light - yellow led off
if (value_water > 700) {
digitalWrite (5, HIGH); // plant thirsty - blue led on
digitalWrite(pumpPin,HIGH);
delay(1000);
digitalWrite(pumpPin, LOW);
status=1;
}else{
digitalWrite (5, LOW); // soil is moist - blue led off
digitalWrite(pumpPin,LOW);
if(status==0) {
digitalWrite (2, HIGH);
delay(300); // wait for a second
digitalWrite(2, LOW); // turn the LED off by making the voltage LOW
tmrpcm.play("15sec.wav");
delay(10000);
// delay(300); // wait for a second);
}else{
digitalWrite (2, LOW);
void updateThingSpeak(String tsData) {
if (client.connect(thingSpeakAddress, 80)) {
client.print("POST /update HTTP/1.1\n");
client.print("Host: api.thingspeak.com\n");
client.print("Connection: close\n");
client.print("X-THINGSPEAKAPIKEY: " + APIKey + "\n");
client.print("Content-Type: application/x-www-form-urlencoded\n");
client.print("Content-Length: ");
client.print(tsData.length());
client.print("\n\n");
client.print(tsData);
lastConnectionTime = millis();
if (client.connected()) {
Serial.println("Connecting to ThingSpeak...");
Serial.println();
client.flush();
// client.stop();
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    • Planter Challenge
      Planter Challenge
    6 Comments
    great stuff.!! are you familiar with my work.?
    i can suggest updating to nodemcu + blynk to display data and control watering/light from smartphone
    yeah bro, thanks a lot. will try to modify it soon :)
    thanks a lot! :D
    Nice project! I am currently building something very similar (Instructable coming after the Instructable for my Boombox), and congrats for your award.
    thanks bro, not yet complete, still in final exam week, will be continue after my final exam finish
