And the idea came. Is very simple, chip, effective and no skills needed but only 2 materials some soldering and the result make you and your tool happy...
Materials
-Any ON/OFF switch for 110 or 220 V AC will be fine. I used one like the desk lamp use
- Any diode above 1N4004
- Some isolated electric tape and thermal shrink cable tubes
- Any cable cutter and stripper
- some minutes of our valuable time
Remove these ads by
Signing UpStep 1Lets do it boys!!!
Now sold the one end of the diode to the one end of the striped cable ( the other end with the short striping). Use thermic covers where needed. And solder this at the one pin of the switch.
The other end of the diode goes to the long striped cable and try to solder it close to the cable edge like in the image. Now cover the rest enough and leave about 3mm to solder this end to the other pin of the switch. Make sure that all parts are WELL ISOLATED and no short circuits will are presents. Heat the thermic covers and check again. Are you sure all are ok? Well done! fit the circuit inside the box of the switch or if you use any other switch make sure are well tied up and well protected. Use the screws to cover the switch or make a small paper box if you will use any other switch.
The final result will be like the image
Its very effective!!!
