SMG & Stock.
Introduction: SMG & Stock.
Here is small compact gun i made, Reminds me of the SMG. I also added a stock to the design, to make it more stable and allow for a more precise shot. It is not really bringing in any new ideas to the table, it is just a new design. Hope you like it and can follow the instructions easily. Any ideas for improvement or look would be greatly appreciated.
Step 1: The Barrel & Handles.
If you look at the below image, you should easily know what you need to make these parts. Also you should have a idea on how to make it too. If you have any questions on how to make these parts, then please leave a comment.
Step 2: Stock.
The stock is fairly simple just join all the parts together as shown. Do not connect it to the rest of the gun, until you have placed the ram into the barrel. To save yourself time and frustration of taking it apart all the time.
Step 3: The Ram.
This is not that hard, just connect in as shown in the picture. As a tip, use Cello tape to stick the pieces to the actual rod. ( Only the Grey piece ) Saves it from disconnecting when loaded and also with enough tape in the way. It can absorb much more pressure when using more elastics. ( More power )
The Brown little pieces at each end, allow the ram to run smoothly across the top of the stock. Also giving a easy reload, by pulling it back.
Step 4: Setting Up the Elastics.
The main elastic for the trigger should be stretched as shown in the picture. The other elastic should be coming from the back of the ram to the very front resting on the two Grey tips of the rods. It is up to you where you would like to tuck the stretched elastic. I would recommend tucking them underneath the red pieces, in the groves. Out of sight.
Step 5: Connecting the Stock to the Gun.
Tip: Do all this after placing the Ram into the barrel, then get all the elastics on now before connecting the stock.
You probably already know where you have to connect everything. Make sure the Grey rods on the stock clip into the Yellow pieces on the Barrel. Also remember to clip the other Grey rod underneath, where the space is.
Step 6: Finished.
Thats it, just make sure all the parts are connected well.
This Gun fires: Green pieces, White rods, blue rods and also Yellow rods.
Tip: I would recommend using the blue and Yellow pieces.
Hope this was easy to understand, i would appreciated comments for improvement and looks.
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
    • Pocket-Sized Contest
    here is another gun i have made i will be putting the guide up soon. It is meant to resemble the AK-47, also has a nice recoil to it. Very powerful too.
    hows this for an ak47 (true trigger)
    more like a sniper
    Yeah I know, (now) I was modeling after a G.I Joe gun And thought it was a m16 Later to look up ak-47 on the internet i.e Google.
    My unfinished ak47
    Is that kinda a mix of my gun with some mods? (p.s. that looks pretty cool :-)I like it.)
