loading
Step 10: Changing your Phone's Settings
You need to change the settings on the phone and change some with your SIM card provider so that no junk SMSs are received. I used a new SIM card, I did not disclose the number to anyone and I suggest you do the same to avoid unwanted calls/SMSs
The first step would be to register yourself on the operator's DND(Do Not Disturb) list for calls and SMSs. That would prevent any telemarketing calls from making your system go bonkers!
Then set the following settings on your phone:
1. Set the "Vibrate Once" alert type for SMS received.
2. Change the main menu order so that the SMS menu is on top of the list.(optional)
3. Delete all SIM card (NOT phone) contacts and keep only one number saved under any name.(Phone number of the person who will receive the "error" SMS)
Hi Kabir, <br><br>Some constructive comments for your project:<br><br>1.) A proper circuit diagram as well as a photo diagram, for those that can read them.<br><br>2.) When wiring a plug top, make SURE that the Earth wire is LONGER than the others, so the last wire to snap, if you jerk it is always the Earth.<br><br>3.) TO detect the MCB trip, use an opto isolator to measure the voltage across the motor. If you want to know how, ask me. Its still a pretty cheap solution, but definitely more reliable in the field.<br><br>4.) You can reliably detect the phone ring, without opening it by using the earphone and a simple detector circuit.<br><br>5.) Sony-Ericsson phones for sure (don't know about Nokia) put out logic-level serial comms on their &quot;USB&quot; connections depending on what's connected to them - so you could talk directly to the phone, if you want for future credits.....<br><br>
I'll contact you after my exams(going on presently).<br> <br> As for the proper circuit diagram, I din't manage time to upload one. I will upload it after my exams are over.
<p>hi kabir.. can U send me your program and circuit digram on my mail..</p><p>actually I am facing some problem, when eorking for gsm and interrupt ...its urgent kindly help me........</p><p>my e mail id is ppritam10@gmail.com</p>
Very impressive. The whole area of remote agriculture management is ripe for applications of GSM technology. Your thought of adding detection of water level to turn off the pump is really vital in that too much water can be as bad as too little, depending on the crop. Other applications would be managing feed and water levels for livestock, detecting flooding, managing wind turbines, reporting intrusion, remotely opening and closing gates to allow stock to move between pastures or return to barn, or remote monitoring of aquaculture/aquaponics systems. <br><br>Would it be possible to have all messages received by the remote device also sent to the operator's cell phone? In that way the operator would be alerted in case someone attempts to hack into the system. It might also be possible to use custom identification like unique rings for messages from the operator and ignore all others.
Yes it would be possible to FORWARD the recieved messages to the operators telephone. <br> <br>Nice ideas. Added them to the last step. <br> <br>PM me if you need any more help/instrutions.
<p>hello KABİR,</p><p>I am working on a project about wireless irrigation system with solar energy.</p><p>I have 500 w energy.I want to pump the water with a motor.</p><p>I see your project very useful for me and congrats.</p><p>Can you send me the documents?please</p><p>orhansen2014@gmail.com</p>
<p>Hello kabir.. can U plzz send me your program and circuit digram on my mail..</p><p>tank you...</p><p>hemredemir@gmail.com</p>
Hey brother plz send the circuit contact me my twitter id-@abhijeetmohara9.twitter.com
<p>Nice project idea, nearly what is the cost of this project.</p>
<p>hi,brother i like your project very much and i need your help ,can you send me a neat circuit diagram and program and if you have full video of this project please send it to my mail id:naveen1430@gmail.com. if you are updated this project with your ideas please send it to me.bye</p>
<p>hi kabir con you mail me the program without the mcb circuit part</p>
<p>Hiiiii kabir.. can U plzz send me your program and circuit digram on my mail.. <br>Your project is very interesting,,i want to make this for my family people....plz do help</p><p>nishant.panwar18@gmail.com</p>
<p>hi brother .Can you please send me a neat circuit diagram and program. </p><p>my email id is aqib.mehmood96@yahoo.com</p>
Tell me about connections of tip 122
Is the ldr led circuit write because a single terminal of ldr<br> is connected to 5v and Gnd both
<p>hi kabir ,i m also doing this project as my final year project .so plz give me full ckt diagram to my emai id:- ashwinvasudevan.c@gmail.com . please give me as soon as possible. Will be waiting for ur reply. thank you</p>
please tell me the phone from which you have extracted the circuit
how can u program if it is a password protected thing
hello, i was impressed by your work, thanks, by the way i am currently doing my final year project , with same topic, but i am using arduino and wavecom GSM modem controlling stepper motor output with sensor input(high or low), <br>so i was thinking if u could e-mail me the code, so will try to learn and my project too. pls reply soon <br>thanks
very nice project. your method is a solution to the expensive gsm modems. it would be nice though to have a company to produce mobile phones which comunicates with uc. keep up the good work
Actually some Sony Erricson phones can be operated by TTL level serial commands, <br> <br>The older ones, most notably the 168i, could be operated via its headphone jack using simple AT commands. <br> <br>Lets hope it is possible in modern phones. <br> <br>Kabir
I executed AT commands on SE K510 and K750 phones. You can read, send, delete sms. Phone will notify you when it gets sms message. You only have to make on arduino programmable decoder of PDU message format . Then you get what number sent message and what command was there.
i have ythe exact same phone and i am finding it impossible to open
Mine is held by clips on the inside. <br> <br>It helps to have a prying tool. I hade to use some force before i could open the clips. <br> <br>A good place to start prying is the battery charging port on the side. <br> <br>Hope you are making one of these! <br>Kabir
Thanks, and im making one but using for a different purpose, as kind of a home automation controller
I have the same phone 2, but it has screws and no clips, but my jewlers screwdriver set cant open it :(
these are just 1A relays are the good enough to control the irrigation pumps?
hi kabir ,i m also doing this project as my final year project .so plz give me full ckt diagram my emai id:-pratik_patel_77@yahoo.co.in
amazing man im also 13 so were did u get the idea frm did u saw how to make it frm some websites???or u designed ur own ciruit???? and how did u bcome a pro member here???? u paid???
For any question not related to the instructable PLS PM me. dont post it on the comment board.I designed the circuit myself as i said b4 <br>
hey i see that ur frm india me too, how old ae u ???? just amazed to see!!!and who helped u with the circuits????
i am 13 and no one helped me with the circuits. <br>
hi this one is a briiliant idea. n being a final engineering student m trying for the same as my project so could you please help me out?
u gave use ur number in the one video!
Really beautiful work Kabir. A model Instructable. <br><br>Well done. <br><br>Steve
Thanks! Please Vote !
It is still a bad idea, because your provider will still send a monthly update text regardless of you being on the DND list.... I suggest you use a Linux netbook hooked up instead of a phone, it would have far more security and functionality. ex.: time control, on, off, you can even use ssh to connect to it.....<br>
The aim of the system is to be cost-efffective. I will design the V2 the system with these modifications.
Well done.<br>It will be very useful to rural India if you can find a sponsor to make it and market it at an affordable price.<br>congratulations.
My design is based on rural India. I am based in West Bengal.The pictureis from our own farmlands.
Amazing! I had a similar idea when I was in Japan. Most of the rice fields there are irrigated using fully manual systems so I thought something like this could be handy.<br><br>Great work!
Thanks! Please vote for me in Sparkfun Microcontroller Contest and The Epilog challenge if you like this instructable!<br><br>Please post pictures if you get around to doing this.
For sure!<br><br>Also, I'm thinking of developing a hichhiking system that is similar to a ride share board except it would work in real-time on smartphones or maybe a dedicated device. It would be a quick and easy way of asking all of my neighbors for a ride into town or for them to offer a ride. I can't program very well at all so I need lots of help if this idea is going to fly. <br><br>I can explain the idea in more detail if you are interested in helping.
You can PM me anytime.
About This Instructable
123,242views
316favorites
License:
Bio: M.H.Kabir is a green geek who likes recycling and loves instructables and DIY among other things such as microcontrollers, embedded systems and photography ... More »
More by mhkabir:Recycled HDD Powertool (Disk of Prometheus) Top Aquarium Projects for Aquarists Mhkabir's Room-cum-Workshop
Add instructable to:
