Introduction: SNES Controller Into a Mouse Mod
Picture of SNES Controller Into a Mouse Mod
A quick and easy way to turn a SNES Controller into a working optical mouse!
Step 1: Materials
Picture of Materials
Materials Needed:
Dremel Tool
Super Glue
Two-Button Optical Mouse (without scroll wheel)
SNES Controller
Screw Driver
Tweezers
optional (Heat Gun and Razor Knife) for cleaner cuts
Step 2: 1. Take Apart the Mouse
Picture of 1. Take Apart the Mouse
Take a screw driver and take them both apart.
Make sure you don't mix up the parts.
Open up the mouse and take out its guts. Keep them.
Throw away the case.
Step 3: 2. Take Apart the SNES Controller
Picture of 2. Take Apart the SNES Controller
Now open up the SNES controller. keep the case and buttons, throw away the guts.
Step 4: 3. Grind Down Plastics
Picture of 3. Grind Down Plastics
The case should be pretty simple looking.
You have a top and a bottom.
They will need to have certain parts ground down so the mouse guts will fit inside.
It is as follows:
Bottom
Top
Step 5: 4. Cut Hole for Optics
Picture of 4. Cut Hole for Optics
Now that you have ground them down, the mouse guts fit inside.
One problem you need to cut a hole in the bottom of the SNES case so the optical part of the mouse will work.
This is where you cut.
I used the cutting blade on the dremel tool.
You can also use a heat gun and razor blade if you have access to these.
My cut is quite crappy but it will do.
Step 6: 5. Glue
Picture of 5. Glue
You aren't done yet. Now you have to glue down a few buttons so they don't fall inside. I have them circled on this next image.
Careful not to glue your fingers, use tweezers if you are bad at it.
Step 7: 6. Mount Mouse Into SNES Case
Picture of 6. Mount Mouse Into SNES Case
Now you have to fit the guts into the case, like this...
Don't put it in backwards!
Now place the bottom part of the SNES case on the back.
Glue the topmost corners together along with sticking in two screws that are located on the right and left. (they are the only usable threads left, its not hard to figure out).
Step 8: 7. Enjoy!
Picture of 7. Enjoy!
You are all done!
Brutus Ultimatum (author)2014-11-08
WHY?!
anthonyyy0 (author)2010-08-10
this doesnt seem like it will work... how can you just stick the guts of the mouse into the controller so that pressing the buttons of the controller would trigger right/left clicking?
Scytheon3 (author)2009-10-31
Would'nt it be better to use an adapter to convert the cable to usb then use something like Xpadder to map the buttons and dpad to keyboard and mouse buttons
Lance Mt. (author)2009-10-28
 YOU MOOONNNNNNNNNSSSTTTEEEEERRRRRRRR!!!!!!!!!
How could you do that to a snes controller
Ideal_Ideas91 (author)2009-06-30
needs scroll wheel. Nobidy will use this without a scroll wheel. Its just to useful!
Decepticon (author)2009-06-26
You left out how to get the buttons lined up. I think this would be difficult to use since the wire is coming out of the side instead of out of the top.
they acutally line up perfectly no soldering needed.
About This Instructable
9,236views
11favorites
License:
More by theurbanraptor:SNES Controller into a Mouse Mod
Add instructable to:
