3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SNES to Parallel Port
The basic steps to modify your SNES controller to connect to your computer via the parallel port.
Step 1Strip SNES controller cable
Strip the end of the SNES (Super Nintendo Entertainment System) controller cable (the end that connects to the SNES), and tin the ends of the wires. If you don't want to cut up your controller you can just stick wires in the end that plugs into the SNES according to the diagram in step 3.
Alternatively (what I did), you could replace the SNES cable with one from something else, that way you don't need to chop up the controller. In my case I had a broken NES controller that I borrowed a cord from. It is also recommended that instead of cutting the cable you get a SNES controller extension cable and cut that up. In either case the steps are the same.
112 comments
1-40 of 112next »
Dec 30, 2008. 10:49 PMjitinchigo says:
is it possible to just connect the snes wires straight to USB wires
all i noe is that:
Black(USB) = Brown(SNES)
Red(USB) = White(SNES)
where do i connect the other wires that are left on the SNES controller.
If you noe please email me at azn_guitarist1@yahoo.com.au
please reply ASAP
THNX!
Mar 27, 2012. 12:04 PMbike_gye says:
hear use this ti warks grate
http://www.retrousb.com/product_info.php?cPath=21&products_id=44
Mar 17, 2009. 12:51 PMMr. Squishy says:
I have a guide on how to do a USB one. http://www.instructables.com/id/USB_control_pad_hack/
Mar 28, 2010. 9:58 AMBlackAngel999 says:
I'll do ya one better. They make these things called USB>LPT adapters. Most all of them use the PL-2305H USB>1284 bridge, which supports all of the pins from a parallel port.
Oct 16, 2010. 8:11 AMyawgmoth1 says:
Would there be a memory caching issue with that?
Mar 30, 2011. 11:17 AMHarrymatic says:
Thank you very much for this great instructable, I made mine with a very cheap aftermarket controller that I got online and a few leftover parts from other projects.
Oct 26, 2010. 5:59 PMtoogers says:
you'd probably be better off using the keypad hack, where you wire controller's buttons to keypad's buttons.
Oct 13, 2010. 8:36 AMyawgmoth1 says:
I'm going to be adding an instructable soon for the original NES pad to printer port.
Sep 20, 2010. 3:35 PMzack247 says:
any way to do this with a ps2/1 controller?
cool instructable though, im gonna make one of these, it'll work the same way fro a nes, right?
Jun 18, 2010. 5:50 AMdudeishfish says:
Would it be possible to do the wiring straight into a parallel-usb wire?
Apr 12, 2008. 3:28 PMsanty22 says:
would this work with a sega genesis 2 controller??
May 1, 2008. 3:02 AMultimatesx9 says:
the sega Genesis\Mega Drive contrrollers use the same firmware in every version of the controller, it really does make a difference if use a Japanese pad in a genesis.
Feb 27, 2009. 5:37 PMsanty22 says:
YEAH.... DIDNT ANSWER Will this Wire connection thingy work with a SEga Controller?
Dec 1, 2009. 8:50 PMyawgmoth1 says:
Not sure why people like SANTY here need to cop an attitude with people that are only trying to help. You're obviously not intelligent enough to figure this out on you're own, so at least show a little respect to those who can.
Nov 14, 2009. 4:40 PMwillrandship says:
he means yes. Look on the ppjoy web site for diagrams.
Mar 3, 2009. 6:55 PMultimatesx9 says:
No, you need to find the Sega to parralel schematics to do that. You might find them on here, otherwise, you got google right beside ya
Apr 24, 2009. 12:54 PMCapt. Fat says:
Would this work with a N64 controller??
Apr 25, 2009. 4:14 PMCapt. Fat says:
crap.... Oh well Know a way to power a home made ipod speaker??
Nov 14, 2009. 6:00 PMwillrandship says:
You mean for an amp? Here is a good diagram. Substitue any power you want, and use any power source. Mix and match for good resistors.
Nov 15, 2009. 5:09 AMCapt. Fat says:
thanks for the diagram and all. but i really can't understand electrical diagrams like tht. and i gave up on the idea anywyays. thanks anyways though
Nov 15, 2009. 9:47 AMwillrandship says:
OK. It was just a common amplifier anyway.
Jun 23, 2009. 9:55 AMAlternateLives says:
Could you hook the controller up via serial port?
Nov 14, 2009. 4:39 PMwillrandship says:
If you look into PPJoy, which he is using, there is a way to hook them up through serial, but it would require some sort of microcontroller, like arduino. If you go that route you're better off trying to make a modification to this project. That will use key presses, which you set as keys in emulator. Let me guess, you have a laptop that has no parallel?
Oct 28, 2009. 10:01 PMyawgmoth1 says:
First off, great instructable! I just tried mine with a slight difference. I didnt have a "cap" for the parrelel port cable so I chopped one end off (both ends we're male) and took note of the color coding to the pins. From there I just wired the SNES pad up to it. I used the White wire and Brown wire for usb power. Alas mine does not work....I think I did a shoddy job on the soldering maybe? The wires from the snes pad are AWFUL! They are those fabric type of wires. I'm going to try again tomorrow without those crap wires. I'll just solder better ones to the pad internally.
Sep 1, 2009. 10:44 PMCann0n says:
I didn't add the diodes or use the SNES's power wire and it works well with linux.
Jan 24, 2008. 3:31 PMultimatesx9 says:
like the instrucable, only i dont have an NES or SNES pad, but i have 4 Mega Drive pads, i know the software can handle Genesis pads (so it doesnt matter if i use Mega drive as its the same pad) but is there a way to make a parrel port thing like you made without maodding the acctual end of the controller?
Jul 4, 2009. 6:30 PMwillrandship says:
Actually, I once did a SNES mod where I had both a SNES plug and a Parallel plug on the ends. I did this by popping the shell on the plug and soldering to the exposed wires. As far as I know, it worked perfectly. Just don't plug in both at the same time.
Apr 27, 2009. 10:41 PMcrrimson says:
I just did an instructable for the Genesis controller here: http://www.instructables.com/id/Build-Sega-Genesis-Controller-Ports-for-your-PC/
Jan 26, 2008. 3:17 PMultimatesx9 says:
yeah, found that you could buy DB25 male to DB9 male adapters in maplins, put that in, and now it thinks im always pushing button 6, and i cant mod that, cos its got solid platsic around it.
Feb 12, 2008. 2:41 AMultimatesx9 says:
but i have used your advice and used a 1.5m female serial cable, stick paper clips in that, selotaped it together, but i stuck wires in where the white and brown cables are and i power it from a DC plug set at 4.5 (either that or 6v), havent tested it yet, should work tough
Sep 4, 2008. 4:48 AMmatstermind says:
what kind of diodes are those?
Jun 26, 2009. 6:19 AMcrrimson says:
Get 1N4142 diodes, those were recommended for the other parallel port controller projects, and you can find them at radio shack or online.
Jun 26, 2009. 11:20 AMmatstermind says:
thanks
Jun 12, 2009. 9:41 PMmr monoply33 says:
I believe they are more specifically 3.6 volts zener diodes, if your still wondering.
Jun 13, 2009. 5:27 AMmatstermind says:
sort of, thanks
1-40 of 112next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Hungry_Myst
