3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SNES to Parallel Port
Step 2Powering the controller
There are several ways to power the controller. The cleanest way is to draw power directly from the parallel port with diodes. You can also get power from the USB port or from an extra power cable inside of the computer (if you aren't using a laptop).
To draw power from the parallel port attach a diode to pins 4-9 on the parallel port connector according to the diagram below. The +5V end attaches to the white wire on the controller (make shore that the diodes are aligned correctly, the black stripe should point away from the parallel port).
Otherwise you can strip a spare USB cable and attach the controller's power (white) wire to the red 5V wire on the USB cable and the ground (brown) wire on the controller to the black/ground wire in the USB cable.
12 comments
Jun 19, 2008. 11:33 AMSomeguy_0069 says:
for this... can you hook all the wires onto the usb cable and it still work?
Jun 19, 2008. 8:16 PMSomeguy_0069 says:
I meant to ask where the rest of the wires would need to go in order for the controller to fully function, and I think this is being asked in the wrong step, not sure though.
I deleted my previous comment and just replied to this post so I'd avoid double posting :)
Jun 21, 2008. 9:21 PMSomeguy_0069 says:
OK, I've found a page that I can infer the usages of the DB25 to DB15, and I will proceed. I really hope this doesn't take any soldering @_@
Jun 20, 2008. 12:41 PMSomeguy_0069 says:
Ah... Thanks very much! One question... does it have to be DB25 or can it be a DB15? If the latter: Would you explain how it would go with all the pins on the 15-connector?
Apr 29, 2008. 9:31 AMjfar_22 says:
Whats kind of diode is that and its rating?
Mar 13, 2008. 8:25 PMdeathknell says:
what might happen if the diodes where left out entierly?
Mar 13, 2008. 2:45 PMdeathknell says:
Soooooo, um, I'm like a really super cheapo, so could you just rout all the pins mentioned above through the same diode?
Nov 28, 2007. 7:55 PMchanfle says:
...what? I think this step needs actual pictures in progress..
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Hungry_Myst
