3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SNES to Parallel Port
Step 3Attach everything else
The yellow/clock wire connects to pin 2, the orange/latch wire connects to pin 3, the red/data wire connects to pin 10, and the brown/ground wire connects to pin 18 (if you are powering trough the parallel port).
9 comments
Dec 30, 2008. 10:49 PMjitinchigo says:
is it possible to just connect the snes wires straight to USB wires
all i noe is that:
Black(USB) = Brown(SNES)
Red(USB) = White(SNES)
where do i connect the other wires that are left on the SNES controller.
If you noe please email me at azn_guitarist1@yahoo.com.au
please reply ASAP
THNX!
Mar 27, 2012. 12:04 PMbike_gye says:
hear use this ti warks grate
http://www.retrousb.com/product_info.php?cPath=21&products_id=44
Mar 17, 2009. 12:51 PMMr. Squishy says:
I have a guide on how to do a USB one. http://www.instructables.com/id/USB_control_pad_hack/
Mar 28, 2010. 9:58 AMBlackAngel999 says:
I'll do ya one better. They make these things called USB>LPT adapters. Most all of them use the PL-2305H USB>1284 bridge, which supports all of the pins from a parallel port.
Oct 16, 2010. 8:11 AMyawgmoth1 says:
Would there be a memory caching issue with that?
Jun 18, 2010. 5:50 AMdudeishfish says:
Would it be possible to do the wiring straight into a parallel-usb wire?
Jun 23, 2009. 9:55 AMAlternateLives says:
Could you hook the controller up via serial port?
Nov 14, 2009. 4:39 PMwillrandship says:
If you look into PPJoy, which he is using, there is a way to hook them up through serial, but it would require some sort of microcontroller, like arduino. If you go that route you're better off trying to make a modification to this project. That will use key presses, which you set as keys in emulator. Let me guess, you have a laptop that has no parallel?
Jan 4, 2009. 5:28 PMjitinchigo says:
umm.. THNX do you know where i can get such chips and how to solder the few wires of an Snes to the chip? if so could you make a tutorial on that it would greatly be appreciated!
Jun 23, 2009. 9:52 AMAlternateLives says:
I have no idea where you can buy them outright, but I am sure you can buy a cheap controller (or other USB device) and gut the chip out.
Apr 14, 2009. 3:03 PMbike_gye says:
jitinchigo here is a link to show you what to do to tren it in to usb
http://www.youtube.com/watch?v=0PA8Dgaqkbc&feature=related
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:Hungry_Myst
