SNOM 360 Display Fix
4,928
Posted
Introduction: SNOM 360 Display Fix
Fixing the SNOM 360 VOIP phones display issues -- does your screen flicker when you move the phone? Is it dim or non-operational? Learn how to fix the ribbon cable that connects the large LCD on the SNOM 360 phones to the main circuit board and also fix a little engineering issue also.
Step 1: Taking Phone Apart
First of all we need to get to the screws and take the two halves of the phone apart. There are five screws -- you'll need to take the base plate off first. If you can't figure out how to get that part off . . please don't go any further, lest you turn your phone into a smoking pile of charred plastic . . . which I'm not responsible for! The four corners and then the fifth up in the cradle area is all you need to take out.
Step 2: Seperating the Pieces and Spying the Problem
There will still be a little cable that holds the two halves of the phone together -- I didn't bother with taking it loose, because you'll be able to instantly see what the problem is.
Step 3: Fixing First Problem - the Ribbon Connector
The first problem is just getting the ribbon connector cable back where it belongs and then reattaching with glue. In this case I used some hot glue.
Step 4: Fixing the Second Problem -- Cable Stability
This is where I had a little inspiration of creativity -- I thought there should be some other way to eliminate the strain on that cable as the display pivots. There were two screws right there on the board . . . and a drawer full of paper clips. Yep -- I put on my Macgyver cap and decided to engineer a little strain relief system for the phone.
Step 5: Put It Back Together and Test
This is the last part of the whole shebang . . . put the phone back together and see if it works.
    • Microcontroller Contest
    • Trash to Treasure
      Trash to Treasure
    • Science of Cooking
      Science of Cooking
    I don't know what snom 360 is, but this actually looks like a fun Instructable to do to that machine thing. Not too hard, actually...
