3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SOCBOT - The Next Generation Vibrobot
Step 3DOWNLOAD THE CODE TO THE PICAXE
This is the picaxe code I wrote to use with the socbot. As the socbot has no download circuit you will need to program the picaxe on a proto board and then move the programmed chip to the socbot.
The code uses the infrain2 command to wait for one of 3 valid codes from the universal remote. Depending on which code is received, the picaxe will send a 100mS current pulse to one motor or both motors. If the button is held down the current pulse repeats until the button is released.
A copy of the picaxe bas file is included below for download.
MAIN: let dirs= %00010111
BEGIN: let pins= %00000000
infrain2
let b0 = infra
if b0= 16 then AHEAD ' CH+
if b0= 19 then LEFT ' VOL-
if b0= 18 then RIGHT ' VOL+
goto BEGIN
AHEAD: let pins= %00010111 ' Outputs 0,1,2,4 HIGH
pause 100
goto MAIN
LEFT: let pins= %0000011 ' Outputs 0,1 HIGH 2,4 LOW
pause 100
goto BEGIN
RIGHT: let pins= %00010100 ' Outputs 2,4 HIGH 0,2 LOW
pause 100
goto MAIN
Socbot.bas531 bytes
5 comments
Jul 31, 2010. 1:10 AMBoppo3 says:
how do you actually program a pic axe?? i know this instuctable said use a protoboard, but i just dont understand how.... can anyone make an instuctable on programming?
Mar 19, 2010. 3:28 PMFuzzer3legs says:
 What Do I Do
Error: Unknown symbol - dirs
Mar 19, 2010. 3:40 PMFuzzer3legs says:
 Never mind I was picaxe 08 instaid of picaxe 08m
Jan 23, 2009. 6:41 PMklee27x says:
Hey, geeklord. I followed you here, lols. A PICAXE is to a PIC what an Arduino is to an AVR. A PICAXE is a PIC microcontroller with a proprietary interpreter and function library already burned onto it. What this means: You load your BASIC-style code into it's data memory, and the boot-strap program that's already been burned onto the chip takes these instructions and activates prewritten routines in the PIC's native language. This makes a PICAXE capable of doing highly complex functions with simple commands.
Jan 23, 2009. 6:18 PMgeeklord says:
are PICs and PICAXEs the same?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
84
Author:biochemtronics
After a career in industrial electronics I went back to college and now do DNA research.
