SOLAR BAG WITH TORCH AND MULTI PORT CHARGER
1,820
35
Published
Introduction: SOLAR BAG WITH TORCH AND MULTI PORT CHARGER
STEP 1
THINGS REQUIRED
1) DUFFLE BAG/ SIDE HANGING BAGS AS SHOWN IN THE PIC.
2) SEMI FLEXIBLE SOLAR PANEL(1.5W TO 5W) & (5V) .
3) POWER BANK ( 2600mah) OR (10800mah)
4) 1W LED PCB BOARD EASILY AVAILABLE FROM THE ELECTRICAL REPAIR SHOP,OR U CAN BUY ANY DC ELECTRICAL BULB OF 1W .
5) 6 PCS 0.18W LED
6) 6pcs RIVETS 1CM LONG
7) LED BULB DIFFUSER (EASILY AVAILABLE FROM OLD LED ELECTRIC BULB).
8) SOLDERING IRON.
Step 1: Step 1: ASSEMBLING SOLAR PANEL
FIRST TAPE THE WIRE COMING FROM THE SOLAR PANEL TO THE MIDDLE OF ITS BODY AS YOU CAN SEE THE PICTURE.
PUT THE SOLAR PANEL ON THE FRONT SIDE OF THE BAG AND MARK THE HOLES WHICH WOULD BE SUITABLE FOR THE RIVETS TO ENTER AFTER MARKING BOUNDARY HOLES CREATE A BIG HOLE IN THE MIDDLE OF THE BAG FOR THE OUTLET OF WIRE COMING FROM THE SOLAR PANEL ( REMEMBER WE JUST HAVE TO TEAR THE UPPER CLOTH ON THE BAG FROM CENTER,AND REMOVE THE FORM FROM THAT AREA SO THAT WE CAN GET THE SOLAR OUTPUT WIRE IN THE BAGS POCKET). AFTER TAKING OUT THE WIRE RIVET THE JOINTS FROM THE ALL 4 SIDES AND HERE YOUR SOLAR PANEL ASSEMBLY GETS OVER.
Step 2: Step 2: ASSEMBLING THE TORCH LIGHT
ON THE PCB BOARD FIRST WE HAVE TO SOLDER THE LED /IF WE DO NOT HAVE THE PCB BOARD THAN WE CAN PASTE THE LED DIRECTLY INSIDE THE DIFFUSER WITH THE HELP OF GLUE AND MAKE CONNECTIONS BY KEEPING 2 SETS OF 3 LED IN PARALLEL AND THAN COMBINING THEM IN SERIES.
SOLDER THE 9V BATTERY SOCKET WITH THE WIRES COMMING OUT FROM PCB BOARD. PASTE THE PCB BOARD WITH EPOXY OR HOT GLUE GUN AND LEAVE IT FOR AN HOUR. FOR MAKING IT MORE STRONG TAKE A RIVET AND PUT IT FROM THE CENTRAL HOLE BY TAPING BOTH THE TERMINALS .AFTER THAT TAKE THE DIFFUSER AND GLUE IT FROM THE FENS AND STICK IT ON THE PCB BOARD AND AGAIN LEAVE IT FOR 1 HOUR, MAKE A SMALL CUT BEHIND THE PCB BOARD FOR THE WIRE, WE CAN ALSO CONNECT A SWITCH IN BETWEEN IF WE WANT.
Step 3: Step 3: FIXING OF TORCH AND TEST CHARGING
NOW WHEN WE ARE READY FOR THE TRIP WE CAN CARRY THIS BAG WITH US AND IT WILL CONVERT SOLAR ENERGY IN TO ELECTRICAL ENERGY AND SAVE IT IN POWER BANK .
WHEN OUR ( PHONE ,CAMERA,I POD, BLUETOOTH ,ETC ) ARE NOT ENOUGH CHARGE SO AT THAT TIME WE CAN MAKE USE OF IT. WHILE TRAVELING AT NIGHT PASSING THROUGH THE DARK ROAD WE CAN UTILIZE OUR BAG TORCH WHICH EMITS ENOUGH LIGHT TO MAKE OUR PATH CLEAR. NOW WE CAN ENJOY OUR TRIP WITH OUR HOME MADE SOLAR BAG. IF WE PLACE THE BAG DIRECTLY IN SUNLIGHT FOR 2.5 HOURS THAN IT CAN CHARGE OUR 100% PHONE BATTERY .
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    2 Comments
    Nice project! Although for the next one you might want to consider removing the caps lock :)
