Introduction: SOLAR GADGET BOX
This project of mine wich I'd like to call my "SOLAR GADGET BOX" is basicly a USB solar charger and a 12v power scourse.
The good thing about this box is that it can charge with the sun (SOLAR PANEL)
The box has a shoulder carry strap.
When I came up with this whole USB solar charging thing,I thought but why not make a box to store my gadgets in and combine it with the solar charging.
That is where I came up with this idea.
The awesome thing about this box is that you can take it with you on the go.
I didn't plan on putting my project on Instructables so didn't take photos while I was building it,but I will explain a few things instead.
I used 6mm MARINE PLYWOOD for the box wich I glued together with normal wood glue.
The edges of the box is fitted with aluminium angles wich I glued on with silicon.
On the inside I used black felt to cover the wood and I also used normal wood glue.
The electronical info wich most people such as me are interested in:
The solar panel is a 5W 300MA 21.5V panel.
The charge controller is a SR15-12 model for 12v systems.
The battery inside is a 12V 4.5AH valve regualated battery.
Most solar chargers have like 1200mah,1600mah or 2000mah batterys inside of them wich is not much.I cranked up the anty to 4500mah,so I have a lot of power.
Under this is a few pics that will show you how my box works.I will also give a small description of each picture.
HOPE EVERYONE OUT THERE ENJOYS THIS PROJECT AND PLEASE FEEL FREE TO COMMENT ME ABOUT ANYTHING AND ALSO RATE MY INSTRUCTABLE.
Finalist in the
Off the Grid Contest
