Introduction: SPACE DRONE
This is a quadcopter base space drone. It will be working in space and some other planet also.
The quadcopter type drones are using four rotors and this cause I have used four thrusters based on using solid propellant.
The space drone is working based on four thrusters and fuel materials are used in solid propellant and own oxygen tank.
The acrylic rod is acted as a solid propellant and it will burn by using own oxygen flow.
The space drone is working based on quadcopter principle.
Step 1: First See This Videos
I have to use acrylic rod it will act as a solid propellant and provide own oxygen tank.
Throttle the oxygen flow to control the thruster force.
Step 2: Materials Used
Oxygen cylinder
Acrylic rods
Check valves
Throttle valves
Signal transmitter and receiver
Lithium polymer battery
Thermal insulator
lightweight aluminum frame
Step 3: Design and Fabrication
The vehicle design based on quadcopter type such as X or + type frame has as been designed. The vehicle frame material is using the lightweight aluminum frame.
The X type frame is design based on payload.
The X type frame will attach the metal hose and between using check value and throttle value.
The lightweight aluminum canister is used to load the solid propellant.
The thruster nozzle design is the most important thing.
Note: If you have to operate your drone in space you have to provide ignition unit and consider some other factors also.
Step 4: Working
The four thruster force is controlled by using throttle value
The check valve is used to provide additional safety
The throttle valve is attached to the servomotor to control the oxygen flow
The signal transmitter and receiver is connected to the controller
The controller is attached to the four servo motors.
The four thruster is ignited to increases the oxygen flow it will take off and varying the thruster force to control the drone motion.
Thank you
This is my idea and I don't have enough of money to make a prototype.
Thank you & vote me
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    • Science of Cooking
      Science of Cooking
    Interesting project. Next step, maybe would be to measure the thrust of the engine in relation to the amount of oxygen and acrylic consumption. We would then have an idea of the power available and the weight/thrust ratio and we could then calculate the autonomy of the rocket... keep it going!
