Introduction: SPEEDsSTACK Stopwatch
Picture of SPEEDsSTACK Stopwatch
In this instructable i will show how to make a touch sensitive stopwatch like the SpeedStack's stopwatch.
Whatch it works
First test with the OLED
Step 1: Supplies:
Picture of Supplies:
* Arduino pro mini
* Adafruit OLED screen (128*68 i2c)
* Copper tape
* 2 Leds
* 2 10 Kohm resistors
* 3 220 ohm resistors
* Wire
****** NOTICE: The touch sensitive are actually made of copper tape and resistor using the CapSense lib.
Also, usually i use the Arduino UNO at the planing and designing state and when done change to Arduino Pro Mini
Step 2: Used Libraries :
I used several of them :
1. For the capacitive touch i used the CapSense library.
2. For the OLED display i used several of them that requier each other :
SPI.h - The library is used to communicate over SPI protocol.
WIRE.h - Used to communicate over I2C protocol
Adafruit-GFX-Library - Used to work with the OLED display.
Adafruit_SSD1306 - Used for the monochrome OLED based on SSD1306 drivers.
Step 3: CODE :
Picture of CODE :
#include
#include
#include
#include
#include
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define Red 7
#define Green 8
#define ResetB 6
#define Sensitive 20
#define delayRun 2000
#define blinkDelay 75
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
CapacitiveSensor   cs_4_2 = CapacitiveSensor(5, 4);       // 10M resistor between pins 4 & 2, pin 2 is sensor pin, add a wire and or foil if desired
CapacitiveSensor   cs_4_6 = CapacitiveSensor(3, 2);       // 10M resistor between pins 4 & 6, pin 6 is sensor pin, add a wire and or foil
boolean hold = false, runT = false;
long holdTime, stopWatch;
long total1 ;
long total2 ;
long calculator, blinkCount = 0, over;
int Hours, Minuts, Seconds, Tseconds;
void setup()
  cs_4_2.set_CS_AutocaL_Millis(0xFFFFFFFF);     // turn off autocalibrate on channel 1 - just as an example
  Serial.begin(9600);
  pinMode (Red, OUTPUT);
  pinMode (Green, OUTPUT);
  display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
  display.clearDisplay();
  display.setTextSize(2);
  display.setTextColor(WHITE);
  display.setCursor(0,0);
void loop()
  // *** Read touch-sensors
  long total1 =  cs_4_2.capacitiveSensor(30);
  long total2 =  cs_4_6.capacitiveSensor(30);
  //display.clearDisplay();
  display.setCursor (0,0);
  display.print ("SPEEDsTACK");
  display.display();
  // *** A touch bouth sides
  if (total1 >= Sensitive && total2 >= Sensitive && hold == false) {
    digitalWrite (Green, HIGH);
    digitalWrite (Red, HIGH);
    holdTime = millis() + delayRun;
//    Serial.print ("holdTime = ");
    display.setCursor(0,30);
    display.print ("--READY--");
    display.display();
    hold = true;
  // *** Go green light after delay
  if (millis() >= holdTime && hold == true) {
    digitalWrite (Red, LOW);
    display.setCursor(10,30);
    display.print ("** GO **");
    display.display();
    while (hold == true) {
      //Serial.println ("hold loop");
      // *** Waiting for bouth untouched
      while (total1 >= Sensitive && total2 >= Sensitive && hold == true) {
        delay (10);
      // *** Wating for re-touch
      while (total1 <= Sensitive || total2 <= Sensitive && hold == true) {
        if (runT == false) {
          Serial.println ("                  *** Zeroing ***");
          stopWatch = millis() + 10;
          runT = true;
          blinkCount = 0;
        calculator = millis() - stopWatch;
        //display.setCursor(0,0);
        //display.print (calculator);
        //display.display();
        Hours = int(calculator / 3600000);
        over = calculator % 3600000;
        Minuts    = int(over / 60000);
        over = over % 60000;
        Seconds    = int(over / 1000);
        Tseconds   = over % 1000;
        display.print (Hours);
        display.print (":");
        display.print (Minuts);
        display.print (Seconds);
        display.println (Tseconds);
        display.display();
        if (calculator >= blinkCount + blinkDelay) {
          Serial.println ("***BlinK***");
          digitalWrite (Green, !digitalRead (Green));
          blinkCount = calculator;
      if (runT == true) {
        stopWatch = millis() - stopWatch;
        Hours = int(stopWatch / 3600000);
        over = stopWatch % 3600000;
        display.display();
        hold = false;
        runT = false;
        digitalWrite (Green, LOW);
        blinkCount = millis();
        while (!digitalRead (ResetB)) {
          if (millis() >= blinkCount + blinkDelay) {
//            Serial.println ("***BlinK***");
            digitalWrite (Red, !digitalRead (Green));
  // *** A touch only one side
  if (total1 >= Sensitive && total2 <= Sensitive || total1 <= Sensitive && total2 >= Sensitive) {
    hold = false;
    display.setCursor(32,30);
    display.print ("<<<>>>");
    display.display();
    Serial.print (total1);
    Serial.print ("\t");
    Serial.println (total1);
    Serial.println ("ONE Touch");
  //*** No touch at all
  if (total1 <= Sensitive && total2 <= Sensitive) {
    hold = false;
    Serial.println ("NO Touch");
  Serial.print(total1);                  // print sensor output 1
  Serial.print("\t");
  Serial.println(total2);                  // print sensor output 2
  delay(10);                             // arbitrary delay to limit data to serial port
Step 4: Placing and Painting
Picture of Placing and Painting
After all the electronics was set I placed all the componets and wires using 3M dubble sided tape and a regular electric tape.
Then I designed and printed a sicker, and sicked it to the stopwatch.
The area were the sticker does not cover, i painted using PlastiDip paint.
AlbharathEinstein (author)2016-06-22
Hi, I really love your project. I am now building the same but I am using an LCD keypad shield so any idea how to conenct the rest of the parts to the shield.
Hi,
I never used the LCD keypad shield, but i know there are lots of libs and guide to use it, it will probebly take some twiking of my code to adjust it to the keypad but it should work.
Ok thanksa lot. Ill try n let u know if it works
About This Instructable
668views
6favorites
License:
More by udubinsky:ENC28J60 Using Ethernet With ArduinoElectro Double Pie Face Showdown Never Forget It on - Energy Saver
Add instructable to:
