This is a “SPIRAL LED CHANDELIER” with 240 LED’s working on AC current.
It looks very decent when you switch off all the room lights at night.
Gives a soft light throughout the room and you can use it while watching TV.
Hang it in the Dining room and have a candle light dinner.
This is a sister model of my instructables “LED CHANDELIER” posted earlier.
Remove these ads by
Signing UpStep 1STEP-1
Take a piece of Mild Steel wire of 1/8 inch diameter and 12 to 14 feet long.
Wind the wire into a spiral with a hook at the top.
This is used as a support for the LED Necklace and the Transformer.
See the Photograph for guidance.
Tell your parents that this is a VERY SAFE Project as it runs on only 12 volts.
Getting Shocked Dose not arise.
kucch aur use kiya hain kya uske saath or bas directly 2 leds ko unke connectors ko ek saath solder kar dia hain?
chandelier accha hain.. but din me utna hi bhadda hain :) well how uses it during the day anyways.. accha project hain.. will be making soon as i finish up with my aieee... but usme ill put alternate color leds :)
Hum ne perforated hardboard ka use keya hai jo LED ka support deiya hai soldering ke leya.
LED ko hole me dal do, phir uska legs ko bend karo aur solder karo.
L..D ko hole me dal do, phir uska legs ko bend karo aur solder karo.
lolzzzzzzzzzzzzzzzzzzzzzz
Main Bangla, Hindi aur Oriya ma bhe baat kar sakta huin.
but i am not understand in step-2
1.4 come from ?
“....16 volts transformer without load shows 18 volts output.
So 18 x 1.4 =25.2volts...“
Capacitor will not work on AC and I want it to work on AC.
An excellent tutorial: http://www.allaboutcircuits.com/vol_2/chpt_4/2.html
Thank you for the link, will go through it.
English is not my mother toungue, mistakes are bound to happen.
So, what you will see is, when you switch on your circuit, all will be fine at first. After a while, the LEDs will burn brighter. Further on, your white LEDs will change color, usually yellow, or greenish. And if you still dont switch it off, it will burn out very soon.
With all due respect, sir, what you need are "LED drivers", which are actually circuits which produces fixed currents, therefore eliminating excessive current in your LED circuits. You can actually build these "LED drivers" yourself. Maybe write an instructable on it? :)
Thank you, Good instructable anyway!
Please read my answer to verence's comments and you will know the theory behind this Instructable.
And yes, you are right, halving the current, halves the heat production. But that doesnt mean that the temperature doesnt increase. And when an LED heats up, it draws more current, therefore heating it up further. Maybe a good heatsink will alleviate this problem. Or an inclusion of a capacitor in your circuit will cap off the voltage peaks found in the AC.
Take a look at this:
http://en.wikipedia.org/wiki/LED_power_sources
under the topic "Power Sources".
There's a topic on "Lighting LEDs on mains" too. Good day.
I like to do things differently which is hard for the learned people to digest, but if it works for a long time without any problem then my work is sucessful though it may not be what the BOOK says.
I have read all about LED;s in Wikipedia. Thanks for the link.
I had posted my LED chandelier about a year back with the same circuit and to this day it is working very nicely without any LED blowing off, so I made this on the same principal and circuit in a bigger scale.
Maybe my methods is unorthodox but I can garentee you that it woirks perfectly.
Sorry texasclodhopper,
NO my polarities are not screwed up.
I am not an engineer and know nothing of SCHEMATIC drawing but I have tried to explain this with another diagram in step 2.
All the LED's are interconnected in the middle.
Both the Rows of +8 and-8 are opposite to one another.
As AC current flows in both directions alternatively so all the LED's are not glowing at the same time but alternately.
Hope you understand my point.
I am really very sorry if I have in any way offended you though I did not mean to.
Many people do the same thing in many different ways, but the outcome is important.
This design was inspired by my friend qs who has posted many such Instructable in this site, before making any judgement I request you to go through them.
THANKS.
merely a suggestion
Is there something I don't know or what?
16 LED one set
16 x 15 sets
= 240 LED's.
15 sets connected in parallel.
RIGHT.
