Step 4Drill the holes in shell.
Its best to make a template to make sure you like the layout before you commit to drilling.
Check to see that the components will have enough room on the inside of the drum without interfering with each other, or the speaker. Also make sure that the components won't interfere with the lugs or the shock mount system.
Mark the center of each hole on the template, and tape it down temporarily. Mark the center of the holes by using a sharp object like an awl or the point of a nail to make a dent in the surface below. Mounting holes for the XLR jack are best drilled with the jack sitting in its hole, so the alignment is perfect.
Pre-drill the holes with a small bit first (1/8" works well), and enlarge to the proper size with larger bits. This will keep the bits from "walking" when starting the holes.
Add Comment
