SPKR MiK: How to make a microphone from a speaker.
Step 6Review the plans and solder the circuit.
I researched how others have wired their speaker microphones and schematics of various direct injection (DI) boxes to figure out how I wanted to build this one.
I've provided a PDF file (below) of my hand drawn schematics so you can print them off and have them at your workbench.
Warm up your soldering iron and follow the schematic. Lines that meet in a dot are connected. Lines crossing in a little "jump" are not connected.
Point to point wiring is actually simpler in this case. This is when components are soldered directly to each other without using a circuit board.
It may help to highlight different sections (paths that are connected together) of the circuit with different colors of ink, then wire one section at a time.
Solder leads to the transformer, and insulate the connections with electrical tape or heat shrink tubing. Then put the transformer into the container and run the leads through a hole drilled in the side. You may want to pad the transformer inside the container with a scrap of foam, cotton balls, or a plastic shopping bag so it doesn't rattle around inside. The connections on the transformer will be less likely to come loose if the transformer does not move.
Solder in the leads for the speaker and label them. Wait to solder them to the speaker terminals until after you have mounted the speaker in step 7.
Circuit Explanation
The configuration of the coils can be changed by the rotary switch (S1).
  • Position 1 Single: A single coil of the speaker is used (4ohms), both 1/4" jacks are wired in parallel with the coil.
  • Position 2 Series: Two coils are wired in series(8ohms), with the two 1/4" jacks wired in parallel.
  • Position 3 Parallel: Two coils are wired in parallel (2ohms), with the two 1/4" jacks wired in parallel.
  • Position 4 Damping: Coil A is normalled to the 100ohm potentiometer, which will electromagnetially dampen coil B. When a 1/4" plug is plugged in, the potentiometer is disconnected, and the input directly drives coil A. Coil B is wired in parallel with the 1/4" output jack.
In all positions, the output then passes through the phase flip switch, through a -20db pad, to one side of the transformer. The transformer's secondary outputs through the XLR jack. (The pins on the XLR jack are labeled.)
The filtered ground can be lifted by opening S4.
4 comments
Sep 9, 2011. 4:03 PMmtschles says:
Your rotary has me a little confused. What is coil B doing when coil A is being driven by the input, and is the dampening output solely coil B? Also, which position are you in when you're using it as a DI?
Jul 16, 2009. 11:20 AMshockadd says:
why the 1/4 in jacks??? Why would you want to use them when you have a balanced XLR output??????? This doesn't make sense to me
Jul 8, 2009. 11:54 AMbazzospazzo says:
hi mate, love the design. ive made up my own sub kick with an 8" speaker with a 5.5 ohm impedance. i wanna install a -10 and -30 pad to go with the -20 you already have. how did you decide on how much resistance to use and also what kind of 100nF filter cap should i use? many thanks baz
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:Aud1073cH
