3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
S.P.R.E.E. (Solar Photovoltaic Renewable Electron Encapsulator), a Compact, Durable, and Portable Solar Energy Generator
Step 4Energize S.P.R.E.E.
Energize S.P.R.E.E.
After all connections have been made ,double check them and test them with a multimeter before connecting to the battery.
Connect the red wire to the positive (+) terminal of the battery, then connect the black wire to the negative (-) terminal of the battery.
Note: The photovoltaic panel will charge the battery even when the charge controller is OFF. The charge controller has to be in the ON position to power 12-volt cigarette lighter socket.
1 comment
Dec 4, 2010. 6:00 PMNoblenutria says:
Don't you need around 14.8 volts to charge a 12 volt battery? Usually the voltage of the panels are higher than the voltage of the battery. I looked at the specs for the charge controller. It says it works with an open panel voltage of 21 to 24 volts. Your panel is 12 volts.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
40
Author:charlitron
