Introduction: SPRING/SUMMER NAUTICAL STRIPED DRESS
Picture of SPRING/SUMMER NAUTICAL STRIPED DRESS
Hello friends here is a tutorial for one of my favourite dresses. It is a very easy dress to make and could be made with any Jersey knit fabric, get creative and try fun colour combinations. You can wear it with leggings and a cardigan in colder climates. Good Luck!
Step 1: Gather Materials
Picture of Gather Materials
  1. One meter or more depending on your dress size of a striped jersey fabric.
  2. Half a meter of a co-ordinating jersey fabric(Optional).
  3. Scissors
  4. Coordinating thread
  5. Sewing Machine
  6. Tape measure
  7. Tailor's chalk
Step 2: Take and Transfer Measurements
Picture of Take and Transfer Measurements
Cut out 2 rectangles or squares with these dimensions
  1. Length from shoulder to shoulder.(if your hips are wider than your shoulder, use your hip measurement divided by 2.
  2. The length of the dress (see image).
Next, fold the fabric in two along the width and measure out these dimensions.
  1. Measure from your Shoulder to Bust (widest part of your bust).
  2. Measure from shoulder to waist.
  3. Measure from Shoulder to the widest part of your hips.
Step 3: Transfer Measurements and Cut
Picture of Transfer Measurements and Cut
Join the marked lines as shown in the image.
Then cut the fabric adding a 1-inch seam allowance.
Step 4: The Neck
Picture of The Neck
  1. Measure 1 inch down from the top corner of the folded side.
  2. Measure about 5 inches across on the folded side.
  3. Join the 2 lines with a curve. (See image)
Step 5: Sew
Picture of Sew
I used a serger/overlocker to sew this dress but you don’t need a serger/overlocker to sew Jersey knit fabrics. A normal 2.5 zigzag stitch will do just fine as it will allow the fabric to stretch or stretch stitch if your machine can do stretch stitches. To find out if your machine can do stretch stitches look for the S.S on the stitch length dial.
  1. Sew along the red marked lines. (see image)
  2. Then mark how low you want your neckline to be, like I have done in the picture above.
Step 6: the Waist Band
Picture of  the Waist Band
Most people say horizontal stripes make you look bigger, I believe that with the right tricks it can do the opposite. This next step is about adding the contrasting waistband to trick the eyes and make you look slimmer depending on your body type. This really works!!
Try on the dress again.
If you are apple shaped- Mark a line just below your Bust (thinnest part of your waist) and make the dress shorter to show off your legs
If you are pear shaped- Mark a line just below your natural waist
If you are an hourglass- Mark a line on your natural waist
If you are a rectangle- Mark a line around your belly button.
if you are an inverted triangle- Mark a like just above your belly button
Now take the dress off and cut across that line (see image).
Next, measure a strip of fabric from your coordinating fabric
The length should be your waist size
the width should be 10 inches
*****Note- Make sure the length of the strip is cut so that it stretches horizontally. i.e cut the length along the grain. Do not add any seam allowance as the fabric will stretch horizontally.
Now fold the fabric in 2 along the width so that is doubled and provides support around the waist.
Step 7: Sewing the Waist Band
Picture of   Sewing the Waist Band
  1. Turn the dress on the wrong side, place the strip on a table place the top half on the strip so that the right sides are together.
  2. Pin in place with a 1-inch seam allowance
  3. Do the same for the bottom half.
  4. Sew horizontally along the red lines.
  5. Now sew up both ends of the strip along the red line with a seam allowance of 1/2 an inch.
Step 8: 9 Finishing Up
Picture of  9 Finishing Up
The arms
Do a simple hem by folding 2cm around the arm and sewing down with a straight stitch length of 2.5.
Do the same on the bottom of the dress.
The neck trim
  1. Cut a strip of fabric this time across the grain 20inches long and 4inches wide.
  2. Fold the strip along the width and press with an iron.
  3. Place the strip on the neckline and pin around.
  4. Trim of the excess fabric and join the two ends together.
  5. Sew around with 1cm seam allowance.
  6. Join the ends.
  7. Steam press the seams down.
  8. Then turn the strip over and steam press down as shown in the picture.
And voila!
Step 9: Congrats!!!
Picture of Congrats!!!
How was it difficult, easy, hard to follow? Leave me a message and I will try to assist you.
Nemi x
watchmeflyy (author)2016-03-22
Both the dress and you look fantastic!
Anemistyle (author)watchmeflyy2016-03-24
Thank you :)
manutea (author)2016-03-22
Nice job, nice woman....
Anemistyle (author)manutea2016-03-24
:) thanks .
DIYfan (author)2016-03-23
Very cute! I look forward to showing this to my granddaughter. It's a flexible pattern with so much potential. This dress is simple and elegant. THANKS!
Anemistyle (author)DIYfan2016-03-24
You are welcome, I'm glad you like it :)
audreyobscura (author)2016-03-23
So good! Your pattern rocks, so simple and it is my favorite shape.
Anemistyle (author)audreyobscura2016-03-24
Aww thank your, you are very kind :)
About This Instructable
2,749views
37favorites
License:
Bio: Hi guys, I'me Nemi and I enjoy sewing, experimenting in the kitchen and creating all kinds of cool stuff. Follow me and lets create ... More »
More by Anemistyle:SLOW COOKED JOLLOF RICE AND CHICKENCHOCOLATE BREAKFAST BOWLDARK CHOCOLATE BREAKFAST CREPES
Add instructable to:
