3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
SQUIRRELIGIG WHIRLYGIG
  MAKE THE SQUIRREL WORK FOR HIS FOOD-The wind will make him do it. This whirlygig can be made in 1 day from throw-away items.
Step 1Whirlygig wind mobiles basics
Wind mobiles-- To make a wind mobile  all one needs is an  action item . This activity will repeat as long as the wind blows.
        We have published several whirlygigs in Instructables that utilize old bottles of plastic. Ref:nstructables by Mistic
All one needs is a rotating mechanism that translates  a propeller rotation into a reciprocal motion. This can be done with a rotating cam attached to the axle as we will shoe here. It can be any size that you want the object to move. In this case we used a one inch diameter cam. It could have been a 2 inch diameter disk thus giving a 1-1/2 inch up and down motion.
     The object to be moved must have a rotating member ,in this case the squirrel's body.It could be a rabbit  ,etc. cracking an egg.
It could be a lady milking a cow. It needs a repeating motion  to succeed .
     The object can be wood ,as plywood. In  this case we used a sheet of  left over gutter repair aluminum .026 in. thickness which we cut out with a shear.A coping saw can be used for plywood figures easily.
     The wind power converter is a propeller. A wooden propeller[ prop] can be constructed from thin wood . We used old drink bottles as a prop. This way we helped out environmentally. Any piece of wood as a 2x4 can be used as a hub for the props.
      The axle can be a problem . We have found some jumbo paper clips that we straightened out  to work fine. You  can use any steel item as a wire coat hanger. Some  hobby shops sell 1/8 in. diam. steel threaded rods and nuts[6-32] for axles.
      Linkage can be a problem connecting the cam to the figure. We used stretch string found in jewelry dept. of craft stores.We also have used stiff wire formed in a loop around the cam connection to work fine.  The string was used to also to stop the figure from rotating too far,this is not needed when using a wire linkage.See materials list .
3 comments
Apr 27, 2011. 9:16 AMRaisedByRobots says:
I hope I make it to retirement age so I can do crazy cool stuff like this
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
39
Author:mistic
A retired electronics engineer -motorola. delveing into new craft ideas and contest entries.
