SSTC Tesla Coil Assemble Instruction
Introduction: SSTC Tesla Coil Assemble Instruction
Logic chase frequency solid Tesla Coil - this TC uses a logic chase circuit to drive the full bridge work, simple installation of finished products, debugging has been completed. Direct power operation (recommended using auto voltage regulator). With arc extinguishing circuit can produce beautiful arc or music arc.
Step 1: Metal Top
need put a Metal strip With tip
Step 2: Ground Wire
this is very important,the wire need connect to ground
Ensure good grounding
Windows, fittings in the box is not the ground wire Fire pipes or heating pipes are needed to make sure they are connected directly to the earth, This is very important
Step 3: Music Board
1.Mode switch button can only be switched when there is no electricity (otherwise damaged) need use square wave Music or midi music
in the intro we offer some test music
    • Epilog Challenge 9
      Epilog Challenge 9
    • Science of Cooking
      Science of Cooking
    • Paper Contest 2018
      Paper Contest 2018
