3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
STARtech Glow Round For Air Cannons
STARtech is a creation of mine. You can find a few extra pictures and a video on my website AegisAvenger.com (look in the WeirdWorks section of the site!) =)
Super
Tough
Air
Round
STARs are specialized rounds I have created for loading into air cannons.
They contain a very simple electronic assembly that makes them glow very brightly at night. When loaded into an appropriately sized air cannon and fired into the night sky, they look like stars, hence STARtech!!
***This particular instructable deals with STARtech rounds that work with 1.5" schedule 40 PVC barrels. Though any size needed can be made with a little creativity!!
Step 1Tools and Materials
Tools and Materials
TOOLS NEEDED:
DREMEL for smoothing the finished product.
RUBBER MALLET for soft but firm "encouragement."
LARGE DRILL BIT creating the cavity inside the round.
WIRE CUTTER for trimming wire.
NEEDLE NOSE PLIERS for fine work with the smaller electronics.
PLIERS for clamping the round while you hollow it out.
GLUE GUN for creating the round and sealing it up afterward.
MATERIALS NEEDED:
TUPPERWARE CONTAINER for holding the Plaster of Paris mold.
ELECTRICAL TAPE for wrapping the CAST round before making the mold.
DEPLETED CO2 12 Gram this is the object you will be casting the round from.
GLUE STICKS you will need 6-8 at least to complete one round.
A23 battery. This is a tiny 12 volt battery more powerful and cheaper than other batteries out there. You can get a pack of two for $1.19 at some stores. Or just snag one out of your garage door opener!
SPDT Mini Slide Switch turns the round on and off.
LED you can get one of these at any radioshack, pick a color you like. For my STAR I chose blue.
ELECTRICAL WIRE you will only need a tiny length to connect the SPDT switch to the LED.
VASELINE acts as a release agent in the casting process so you can get the round out easily.
Q-TIPS helps spread the Vaseline evenly so you don't have any irregularities in your casted round.
PLASTER OF PARIS mix with water and pour into the tupperware container. This will be your mold for pouring hot glue into.
19 comments
Oct 23, 2011. 2:09 AMnerd12 says:
do you have a 'ible for the cannon. i would love to make on of those
Oct 23, 2011. 2:07 AMnerd12 says:
You could use a plastic pipe for the outside and the inner wall. It would hold together better and allow you to easily replace the rubber tip or to fix the internal circuits
Nov 23, 2009. 8:16 AMfrollard says:
Seconded that hot glue isn't a great material because - friction = heat = melted glue on your barrel.  Barrel lube is almost necessary if you use this regularly!
I made one out of a super-high-bounce ball that PERFECTLY fit the barrel taped to a glow stick tail.  Wasn't bright enough.
A good material to use would be the 'compressed' polystyrene ible - melt styrofoam in a solvent (gasoline, mineral spirits, whatever)...mold into your shape while its still pliable.  It hardens DAMN strong.
Dec 14, 2010. 10:40 AMilpug says:
make it out of hot glue, but wrap it in clear packing tape- problem solved
Jul 15, 2010. 6:11 PMRokko8652 says:
This is going to sound like a joke, but couldn't you use a Condom for a mold? I don't know if it would melt, or what.
Feb 19, 2010. 3:40 PMclemsonguy1125 says:
 why not just use a piece or barrel pipe with a end cap in it for the mold, other than that cool, i might try to put a removeable led throwie in it though
Feb 19, 2010. 5:57 PMclemsonguy1125 says:
 looks awesome
Nov 22, 2009. 9:20 AMnein166 says:
Wow thats great. Better than sticking a glowstick in a potato.
Too bad I retired all my cannons. Maybe I'll have to build one now
Nov 15, 2009. 4:42 AMabsolute zero says:
awsome rounds, suggestion for someone below....put some lubricant to prevent sticking.
have i seen you on spudfiles?
Nov 9, 2009. 6:38 PMTommyhzy says:
 Thanks! This inspired me to upgrade my current Ice projectiles.
I'm using these perfectly shaped small yoghurt containers and putting food colouring water inside them. Then freezing them and cutting the bottle off.  (Remember, Ice expands, so leave a bit of space)   These are very cheap, hard, and are easy to mass produce, and VERY biodegradeable.
Just insert a throwie inside these projectiles and use within 24 hours and retrieve said throwie when the ice cracks (:
Your instructable is excellent, with an astonishing amount of creativity, I think a great way to improve it would be to change the filler material, because hot glue projectiles tend to stick to the inside of my barrels...  Well so far that molding scheme is just brilliant, BRAVO Sir! Projectiles will be so much more noticeable during the night now!
Nov 10, 2009. 8:54 PMTommyhzy says:
I think wax would work great, it lubricates the inside of the barrel while remaining quite structurally stable.
I chose the frozen liquid approach because:
(1)No worry about picking up all the pieces, it just melts away and waters the plants
(2)Pretty cheap, at about 0.002 cents each (The yogurt containers are free)
(3)Self-lubricating - As the ice melts inside the barrel, the water forms a thin film that makes quite a great seal against the barrel and also keeps everything slippery
(4)Mass-producible - Just fill those containers with water and food colouring and toss them in the freezer. Done the next morning.
Haha, I love the way you worded the hot glue part  (:
I might actually make an Instructable on it, maybe next week because I have quite a load of school work, tests and projects. Thanks for your support!
A wad of wet scrap paper makes quite a splat when fired against a wall (Giant spitball) and various expired foods also work (Not recommended unless you don't mind cleaning your barrel)... Yeah that's pretty much it for my list of projectile materials. I like to go with organic biodegradable materials, because it saves a whole lot of hassle trying to pick up broken pieces.
I've tried various sports balls, but they are all either too big or have too much friction.
A plastic that could harden on its own could include Epoxy, or you could just use a heated plastic poured into a mould. Epoxy's the only one I can think of so far.
Wow, I've typed quite a lot.
(By the way your thumbnail for this project is amazing, it looks like you're handling radioactive materials)
Haha, I can't wait for the snow to start, Snowballs are one of the most versatile projectiles!
Nov 10, 2009. 4:13 PMosgeld says:
1) this sounds like fun
2) i really need to own some (any)  land so I can do things like this
3) hot glue, wow, props on that, i would have used clear drying epoxy
Nov 9, 2009. 7:31 PMHunter4000695 says:
We need a instructable of the ROBOT!
the one in the picture.
Nov 9, 2009. 6:35 PMboston09 says:
this is coool
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:TitaniumAvenger(AegisAvenger.com)
My name is A.J. Petersen. It is my mission in life to introduce Protection Suit Technology to the world. I am going to do this through a line of suits. An ever-growing un-halting monument of technolo...
more »
