Introduction: LED CUBE: Without Programming [How to Build]
This is a STEP by STEP guide to making a usb powered led cube that requires NO programming. I wanted to make a led cube after seeing a video on youtube but with the limited knowledge in multiplexing I devised a way to make one that only required hardware. Below is a video of the final product.
There are no animations as all leds change on there own as they are automatic colour changing led.
As these leds have cheap timing circuits inside them aren't precisally acurate and all go out of time, that is what gives it the random pattern, because it is random!
Step 1: Parts List: Bill of Materials
For this instructable you will need:
- 100 pcs of fast flash 5mm RGB leds found here on ebay: CLICK HERE -------£8 >>> $14 ish
- 3mm Acrylic sheet A3 (clear, duh), can be found on ebay: TRY HERE ----------£6 >>> $11 ish
- Couple meters of solder, no joke -------------------------------------------------------------£1 >>> $3 ish
- cellotape if you can't be bothered to glue the case (I confess) ---------------------------Already had
- 1mm copper rod, about 70 cm -------------------------------------------------------------Found it in a skip
- A USB cable -----------------------------------------------------------------------------------------------------Free
- Scrap wood to make the jig --------------------------------------------------------------------------------- Free
- Squared paper and glue ----------------------------------------------------------------------------Already had
- 3.3Ohm 2W resistor----------------------------------------------------------- dunno, look for your self, lazy
- And a lot of patience ------------------------------------------------------------------------------------Price less
Step 2: Research: Auto Fading LED's
If we take a look at just one of these special leds, we can see it does this:
- Fades from red to green to blue
- Then flashes, red, green, blue, turqois, purple, orange.
This means it has three leds in one; a red LED, a green LED and a blue LED. The timer built into the led is not perfect so there fore the leds never flash completely in sync with one another. That is what gives it the random pattern, because it is random! See the tagged photo. This led only needs 2 pins as all colour fading happens in the chip ( the black dot ) so you only need to supply power.
Step 3: Constuction: Making the Jig
The uniformity of the LEDs will either make your led cube look depressingly deformed or cute3 (cubically). That is why you will need to make a jig to hold the LED's in place when soldering them together.
To make the jig you will need:
First, glue the paper on to the mdf block, the block must be about 100mm by 100mm, AKA 4" by 4"
Next, drill 25 holes 5mm in diameter and about a cm in depth. They should be about 2 cm apart in each direction.
Finaly, clear out the holes of dust.
- 15 to 18 mm of mdf or other scrap wood (18mm MDF is recomended)
- Prit Stick or other paper glue
- CM squared paper (got it from an old math book)
- A pillar drill or other drill with a 5mm drill bit
Step 4: Construction: Making the Layers
THIS IS THE BIG ONE:
This is the most time consuming process!
- The first photo shows the red and black; positive and negative, rails.
- Insert leds in jig as shown, but all the way round, in all the holes. (see the second photo)
- When you get to a corner put the LED's in place as shown in the third photo, note the angle of the corner LED!
- When you have finisher soldering the LED's all the way round , the structure will be flimsy. Using spare resistors or solid core wire connect the weeker parts of the rails together making sure that you have not connected the positive and negative rails together ( see the forth, fith and six photos )
- Finaly repeat this 3 more times, so you have 4 layers.
Step 5: Construction: Stacking the Layers
You will be delighted to here that there is more soldering: Cough Cough (remeber to work in a well ventilated enviroment)
Lead Poisoning Yet?
Now we are going to solder the 4 layers together. To hold them in place in the clear case copper rod is used as it can be soldered on to the different layers. 5 pieces are requires, one in each corner and one aditional one in the power corner.
Lead Poisoning Yet?
- Put the top layer in the jig ane solder 4 of the copper rods in each of the corners to the negative rail pointing up and away from the jig.
- Now solder the fith rod to your worst corner ( ie the worst looking, as it will be at the back)
- Get your USB cable and strip it down, solder red and black wires to the positive and negative rail (see the last photo)
Step 6: Construction: Making of the Display Case
Finally Comes The Contruction Of The Display Case
You will now nee to cut out panels of these dimension:
Now just tape them in place, which is what I did but a glued case would look better.
- 2 pcs of 110mm by 105mm
- 4 pcs of 135mm by 105mm
Step 7: Conclusion: End of Line
If you have managed to complete one you self, CONGRATS you have too much time and I suggest getting a Job or Work experience. Please can you send me some photos, I would like to see them.
If you liked this instructable please Rate and VOTE for it in the LED CONTEST when voting can begin. Don't Forget to check out my other instructables.
For quite the opposite, CLICK HERE to see my daft punk themed LED helmet
Step 8: Update ! Automatic Turn On
This is an optional addon if you can't take not having any programming. It uses and arduino and a LDR to automatically turn on when dark.
Parts required:
const int analogPin = A0; // pin that the sensor is attached to
const int ledPin = 9; // pin that the LED is attached to
const int threshold = 500; // Change this to calibrate your sensitivity
void setup() {
pinMode(ledPin, OUTPUT);
void loop() {
int analogValue = analogRead(analogPin);
if (analogValue > threshold) {
digitalWrite(ledPin, HIGH);
else {
digitalWrite(ledPin,LOW);
Now wire the components as shown in the simple circuit diamgrams below.
Parts required:
- An arduino
- A standard LDR
- A 1K resistor
- 5X 2N3904 NPN transistors ( or equivalent )
- Some strip board
- And some more solder.
void setup() {
void loop() {
else {
