The other DIY R-Strap examples found here are awesome. Carrying your camera with the standard issue camera strap around one's neck is uncomfortable and unwieldy. So when I started using the R-Straps listed here, I was thrilled with the comfort. However, securing my beloved SLR via a screw in the tripod mount always seemed unsafe while hiking about. What if it unscrewed when I didn't notice? Disclaimer: it never DID come unscrewed, so perhaps I shouldn't complain. However, this is a more secure version of the strap based on a similar premise.
This solution has advantages over tripod mounted solutions in three ways:
1: It's safer. Nothing can come unscrewed and allow your SLR to crash to the floor
2: Your camera can be mounted on a tripod without first removing the strap.
3: You camera can sit flat on a table while the strap is installed.
Remove these ads by
Signing UpStep 1Tried-and-true connector
Thanks for the inspiration!
I use an old leather briefcase strap while she uses a purple laptop bag strap.
I wasn't entirely happy about sacrificing the OEM strap but it's totally worth it.
And you're right, even with a locking washer, thread glue, etc, there's still a chance that with all the movement the bolt from a DIY solution could loosen. Probably not so much the R-Strap since it has turning joints but vs other DIY solutions this is the safest.
What a awesome invention! - I have a Canon 5D Mark II with a 400mm zoom
lens, and the R-Strap looks like a AWESOME solution to me, (and I bought
one immediately) but I added on your idea, and made a DUEL strap mount
and hooked the R-Strap onto them so I have the sling and the security of a
double strap holding the camera.
I also added a Magnetic mount, so when I need to mount it on a tripod,
(and one day I should post that hack here) so when I need a steady surface
it clicks right on, I shoot, I yank and back to slingin!
Jonathan
This strap does not appear to have the slide feature - so I fail to see how this compares in any way to an R-Strap?
1 - It can be worn like a sling across the body (rather than around the neck) which is much more comfortable than a standard strap (equal advantage as with the genuine R-Strap)
2 - It doesn't use the tripod mount which I feel is unsafe (better than R-Strap, unless you have a large lens and would rather mount to the lens itself -- your call)
3 - It's cheap and fun to make.
I'm sure the slide feature is nice on the genuine r-strap, but I have not yet felt like I needed that.
That all being said, the R-Strap is a great idea and I'm sure it's a wonderful product to own. I wish them all the success in the world! I just happen to like my strap better. :)
