3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Safer DIY R-Strap
Safer DIY R-Strap
This solution is very similar to the other DIY R-Straps on this site.  The one distinction is that I believe this is safer.
The other DIY R-Strap examples found here are awesome.  Carrying your camera with the standard issue camera strap around one's neck is uncomfortable and unwieldy.  So when I started using the R-Straps listed here, I was thrilled with the comfort.  However, securing my beloved SLR via a screw in the tripod mount always seemed unsafe while hiking about.  What if it unscrewed when I didn't notice?  Disclaimer: it never DID come unscrewed, so perhaps I shouldn't complain.  However, this is a more secure version of the strap based on a similar premise.
This solution has advantages over tripod mounted solutions in three ways:
1: It's safer.  Nothing can come unscrewed and allow your SLR to crash to the floor
2: Your camera can be mounted on a tripod without first removing the strap.
3: You camera can sit flat on a table while the strap is installed.
Step 1Tried-and-true connector
This is the spot where people have connected a strap to their camera for years.  Let's use it.
12 comments
Mar 27, 2011. 4:36 PMblorgggg says:
Really great instructable! Brought me into the useful (and easy to use) world of gromets!
Oct 5, 2010. 10:54 PMStarstryke25 says:
I destroyed a clearance Target Camera bag to make mine complete with film holster (yes, I'm old skool). Sorry no DIY is available but instead of using the camera strap I used the photobag strap, cut off the plastic and threaded a keyring on. The film pocket was actually the lid so I cut off the lid/zippers and had stitching go all the way around as well as the base heavier material to look the strap through to make it work.
Thanks for the inspiration!
Jun 17, 2010. 7:36 AMtim_programmer says:
If you live in the UK you can get a 'universal strimmer strap' from B&Q http://www.diy.com/diy/jsp/bq/nav.jsp?isSearch=true&fh_search=universal+strimmer&x=0&y=0 This it turns out is a perfect DIY R-strap and has the sliding loop and all for under £6 though not pictured mine also had a little loop of velcro which perfectly fits the standard strap attachment loop on the camera.. long term I dont think it'll last (the metal is wearing the velcro) but when that happens I will likely make something sturdy from the old neck strap. the metal hook on the end is quite bulky (designed for a strimmer after all) but is acceptable - it also means its easy to unhitch the camera from the strap which is nice
May 2, 2010. 11:19 AMc0lin says:
This also allows my wife to attach her own strap to our camera.
I use an old leather briefcase strap while she uses a purple laptop bag strap.
I wasn't entirely happy about sacrificing the OEM strap but it's totally worth it.
And you're right, even with a locking washer, thread glue, etc, there's still a chance that with all the movement the bolt from a DIY solution could loosen. Probably not so much the R-Strap since it has turning joints but vs other DIY solutions this is the safest.
Mar 10, 2010. 3:37 PMmacgeek says:
I never even KNEW about the R-strap!    [WEBSITE:  www.blackrapid.com/ ]
What a awesome invention! - I have a Canon 5D Mark II with a 400mm zoom
lens, and the R-Strap looks like a AWESOME solution to me, (and I bought
one immediately) but I added on your idea, and made a DUEL strap mount
and hooked the R-Strap onto them so I have the sling and the security of a
double strap holding the camera.
I also added a Magnetic mount, so when I need to mount it on a tripod,
(and one day I should post that hack here) so when I need a steady surface
it clicks right on, I shoot, I yank and back to slingin!
Jonathan
Mar 12, 2010. 8:57 AMmacgeek says:
Mar 10, 2010. 4:56 AMadysimo69 says:
You dont trust the tripod screw but you trust that eyelet/material combo? hmmmm............ :-)
Mar 9, 2010. 11:32 AMEbenezerGrinch says:
I own a genuine "R-Strap'.  The main feature of the R-Strap (what makes it an R-Strap) is the fact that it allows the camera body to slide up the strap into shooting position from the hip.
This strap does not appear to have the slide feature - so I fail to see how this compares in any way to an R-Strap?
Mar 9, 2010. 8:12 AMpirateaboard says:
What's the inner diameter of the grommet?  Looks about 1/2".
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:cheshirecam
